![]() Join Date: Nov 2009
Question About Warn Hubs on my K10
I have a '70 K10 with Warn Hubs.
Wanted to put some new wheels on the truck, and wasn’t sure if the new wheels would fit fine with the Warn Hubs, or I'd be limited to certain types of wheels when shopping. Also, if anyone can recommend some good wheel choices for my model, it would be much appreciated. I have checked American Racing and Centerline. Are there some other lines that I should check? Thanks. |
#2 | |
Re: Question About Warn Hubs on my K10
The hubs won't affect the fitment of wheels. It the bolt pattern and center hole are correct, you are good to go. Meaning that if it is intended to fit the truck, the hubs don't matter.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Thanks Longhair.
If anyone else has suggestions on brands of wheels and where to get them, please share. Thanks! |
What?
I prefer the steel wheel and hub cap combo that came from the factory, they just look right to me on these types of trucks.
Check out your local tire/wheel shop, order up a set of steel wheels in a 16 or 17" diameter for around 45 bucks a piece. Then get them powder coated white, and then a set of nice caps - sweet. Then use all that extra cash you woulda spent on the custom wheels on other parts for your truck. Just my .02
Chris 1968 K20 Suburban 1972 K10 LWB PU |
