Old 06-23-2010, 08:20 AM   #1
jasonroman
jasonroman's Avatar
another question for you guys...
well, i bought the truck and was told it had a replaced engine. that a new engine and trans were put in truck....
no papers to prove. but friend that knows a little said engine looks newer
now the guy said 5.7
the papers in glove have 5.7 circled
the sticker in engine bay says 5.0
i was having starting issues and a guy on this forum told me it might be ignition module....so i went to parts store and picked one up.
for the 5,7.
came home and took mine out. and its the wrong part. went back to exchange it. and the girl said she looked under 50 and the part i needed was there.
57 didnt match.
50 did??
so how can i tell what i have in truck??
engine wise and i guess trans too
so far ive been replacing parts as in tune up parts
with 5.7 parts. thats what i thought i had and so i asked for those parts
any way for me to find out exactly whats under the hoood??
thanks for any help
jasonroman is offline   Reply With Quote
Old 06-23-2010, 08:28 AM   #2
bigblock73
yeller
bigblock73's Avatar
Re: another question for you guys...
www.mortec.com will help you determine what engine you have
bigblock73 is offline   Reply With Quote
Old 06-23-2010, 09:08 AM   #3
grinch4om
dang its hot
grinch4om's Avatar
small blck chevy parts interchange so readily that a 5.0 part on a 5.7 or visa versa is common
grinch4om is offline   Reply With Quote
Old 06-23-2010, 09:46 AM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Lots of these old trucks have had the old 305 (5.0) replaced with a 350 (5.7). I know mine has, because I'm the one who replaced it.
I would expect the ignition module to be the same for both. If it is '87 and up, though, I couldn't say. They are a little different.
Does the truck have overdrive? If so, it is probably a 700R4. If not, it is probably a TH350 (or TH350C with lockup) or a TH400. Look here to identify it.
http://www.nastyz28.com/chevy-transm...tification.php
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 06-23-2010, 11:28 AM   #5
dropd80s
dropd80s's Avatar
Link doesn't work.
dropd80s is offline   Reply With Quote
Old 06-23-2010, 11:30 AM   #6
Low87
been here longer than Liz
Low87's Avatar
Slonaker, I swapped from 305 to 350 on my 87, used the same ingnition.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 06-23-2010, 11:54 AM   #7
hotrod_991
hotrod_991's Avatar
i just took a 305 out of mine and but a 350 in it and everything matched up had no issues.
"Buckle up I wanna try somethin!!"
"of course it will hold!, I welded it!"
1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint
hotrod_991 is offline   Reply With Quote
Old 06-23-2010, 12:45 PM   #8
bigblock73
yeller
bigblock73's Avatar
Originally Posted by dropd80s View Post
Link doesn't work.
looks like they closed it down...too bad.
However, a simple google search resulted...
http://www.nastyz28.com/sbchevy/sblock.php
Should get the OP, and others who don't google first, pointed in the right direction.
