Need head info
I wanted to know if its possible to put lt1 heads off a 96 impala on a 74 350 sb? If so do they bolt right in or what would i need to do to get them to work? And is this a good head or what would work better? Im trying build a 383 on a really really tight budget so im diggin for some good deals and i found those lt1 heads. Any info would help to push me in the right direction...thanks.
its all about the +6 inches
Re: Need head info
LT1 heads will not work on a gen 1 small block.
Re: Need head info
what about vortec heads?
Re: Need head info
Vortecs should but you have to change your intake.
Re: Need head info
what kind of intake would i have to run?
#6 | ||
"I ain't nobody, dork."
Re: Need head info
One that fits Vortec heads.
Edelbrock makes them... other prolly do too. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
Location: Aurora,Il ..born,raised and still live in the same house
Re: Need head info
vortec heads for an avg. increase of about 40-70 hp over stock gen 1 heads. But the advice is correct, you've got to change the intake to accept the vortec heads.
plenty of solid advice on this here forum. ha ha.
I love stock! Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine) For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL |
Re: Need head info
Alright so now i found some inexpensive vortec heads but they are the 906 casting. I heard that you should stay away from these that they are worthless and then i hear that they are good that there isnt much diffrence power wise from the 062's. So can someone clear this up for me please. If they are okay how can i beef them up to get some good power out of them? Thanks.
Re: Need head info
any 96 up vortec head is a major upgrade from your stock heads. really the only thing u have to do is minor machining to the guide area for clearance if you run a cam bigger than .480 lift. if your cam is smaller than this, bolt them on with the correct intake (center 2 holes on both sides are different) and your good to go.
1972 super cheyenne 1970 Suburb Last edited by trusty72; 06-24-2010 at 10:06 PM. |
