Old 06-23-2010, 05:24 PM   #1
FL71C10
Potential donor truck
I am still searching for an eninge and transmission for my truck (71 c10 swb 2wd, was originally a v8 automatic truck). I have found a few that I am trying to decide on. Maybe you guys can give me your opinions:
1) I found two motor homes with low mileage 454's in them. One is a 1990 with a carb and a Turbo 400, the other one is out of an 86 motorhome. They both have less than 60k miles and I think both of them are still in the trucks and I can see and hear them run. One is $700 and the other is $900.
2) I have found a few vans with 350's that have around 90,000 miles for about $500 each.
3) I found a 1994 suburban frame with a 350 automatic 4WD. They guy took the body off and may not have all of the wiring or other parts. I think this is a problem waiting to happen due to the potential missing engine computer accessories. $500
4) I found someone who has a turbo 350 transmission that was rebuilt by Aamco in 2004 but he has no paperwork. Don't think it has been run since the rebuild. I thought I could find a small block to use with it but didn't know how longs the seals etc would last in a rebuilt trans. Whether or not it was actually rebuilt or not, who knows?
I'm not a big horesepower guy and I think I would be fine with a small block. How tough is it to put a big block in these trucks and which option (or neither one of them) do you guys think would be a better option?
How much is a crate motor?
Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 06-23-2010, 06:11 PM   #2
thepunisher
thepunisher's Avatar
Re: Potential donor truck
How difficult it is to get a big block to fit depends on how mechanically inclined you are. I don't know the differences between these trucks that came with a big block and those with a small block. I would think the only fitment issue you would have would be with headers or manifolds depending on which you use.
The cost of a crate motor totally depends on what you want, Scoggin Dickey has always done a decent job of selling reasonably priced engine kits. I looked just to see what an inexpensive kit costs and they have one for $2,275.85 (http://sdparts.com/details/scoggin-d...er/10067353kit). That being said there are plenty of local and other national options available. I saw that Summit is reselling a national re-builder, not certain of the name or the cost. I'd say your prices are spot on too, I have seen the TH350's selling for $200 or less and running 350's selling for around $300. I don't know what kind of shape they are in or how complete, I just watch craigslist. Personally there is no replacement for displacement, I'd go with the 454 and the TH400 if you want to keep the cost down and get a complete setup.
Blayne
thepunisher is offline   Reply With Quote
Old 06-23-2010, 10:09 PM   #3
FL71C10
Any other ideas?
Old 06-23-2010, 10:18 PM   #4
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Carb'd Big Block and TH400!
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 06-24-2010, 07:22 AM   #5
FL71C10
Thanks Camaro Nut. Anyone else have any thoughts?
The guy with the 1990 motorhome and 454 is pulling the engine out this weekend. It only has 48000 miles on it. Would that motor fit my truck with the stock manifolds on it? Do I need to get aftermarket motor mounts?
Old 06-24-2010, 11:50 AM   #6
JimmyFloyd
I believe the answer to both of those is yes.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 06-24-2010, 12:01 PM   #7
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Along with no replacement for displacement, think power to weight ratios.. If you can keep a somewhat level head and light-er right foot that big block could get as good if not better mileage than a carbed 350. The tourque that the 454 gives could yield potential to have a pretty high geared rearend.
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
