02-16-2003, 10:28 PM | #1 |
Junior Member
1967 Power Steering Help
I have a 67 step side with manual steering and want to put power steering in. Need to find out what gear box will fit? Any info would be great!
02-16-2003, 10:48 PM | #2 |
Someone else probably knows for sure but I will offer my 2 cents anyway. I know a fellow who put a box off of an 70's Chevy pickup in his truck. He said it bolted right on like it was made for it.
I got one out of a 68 at the wrecking yard but have yet to put it on my truck. I need brackets for a 6 and the donor truck was an 8 so the brackets for the pump don't work.
1968 Chevy - 292 with a powerglide |
02-16-2003, 10:51 PM | #3 |
Now the others dig........
Boxes from 67-79 should fit without a problem.
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
02-16-2003, 11:17 PM | #4 |
Progress = 0%
The '67 frames don't have the indention which allows the power steering box to fit flat against the frame. You'll need the modify the frame to make it work. Other than that, they'll bolt right up.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
02-16-2003, 11:21 PM | #5 |
I'm not sure why, but not all '67 frames are the same. My '67 had the indention in the frame for the box. I used a box from a later model truck as well. I've seen '67's with the indention and without. If you have the indention, it will bolt up quite easily.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
02-16-2003, 11:28 PM | #6 |
Do a search on power steering...check out post "steering gear id".
I posted a response earlier and it shows years and pics of what fits.
72 2wd Blazer 305TBI/700r4., 69 C10 SWB 400SB TPI, 400trans, Step side ., 72 4WD Blazer 350 TBI, 350 serp. drive & "Old Air" ., 94 Camaro Z28 LT1., 94 Grand Cherokee V8, 95 Grand Cherokee 6cyl. |
02-17-2003, 01:00 AM | #7 |
its all about the +6 inches
If you don't have the indentation, and install a later box, you will wear out the box quickly, and probably have darty steering. (ask Wes...he's been there)
To see if you have this indentation, look on your frame rail where your gear box bolts...if it looks like flat stock, you'll need the old style ram assist (like the old vettes) but if it has the indentation like in the pic, you'r OK to put what ever you want on there. |
02-17-2003, 01:50 PM | #8 |
senior member
probly the best thing to do which i did on my 69 gm i sweet talked my neighbour and he gave me the pump and bracket off his 73 chevy cargo van the bracket bolts right on and needs no extra modfication and for the gear box i just got one froma 73 gm out of the wreckers all i had to do was notch out the bumper brackets slightly other than that it works perfect. also it will be harder to find but brackets for chevelles and camaros will also work
69 GMC bagged |
02-18-2003, 06:56 PM | #9 |
Junior Member
power steering
the indentation on the frame that you are refering to, are they on the outside part of the frame? Currently the manual box is using the front 2 and the rear bottom. If these are them I do have them so I can use any box?
02-19-2003, 12:19 AM | #10 |
Outside of frame...look in the center od the 4 bolt holes, you'll see a dent in there.
02-19-2003, 12:19 AM | #11 |
02-19-2003, 05:28 PM | #12 |
Junior Member
Longhorn,
It looks like its flat. Now what do I do? Looking for suggetions? Thanks |
02-19-2003, 05:53 PM | #13 |
If you want to go with the original style power steering that came with your truck (67- early 68), I have the parts , minus the pump and brackets, which are the same for the newer years through 72. It is the ram style and works with a manual gear box.
It came of my burb and worked fine. There was some minor seeping from the piston, which is normal, but no leaks. PM or e mail me if you are interested. Last edited by 68 Suburban; 02-19-2003 at 05:58 PM. |
