Old 06-23-2010, 11:56 PM   #1
'87 Static Slam
'87 Static Slam's Avatar
Cam Suggestions???
dont know if ya''ll had read my post "blown head gasket" or not. but apparently i have a worn or flat lobe in my cam. i will be installing a new one shortly.
any ideas on a cam? i have the late '87 TBI 350 5.7. its been bored 30 over, it has flat top pistons, double roller timing chain, some magnum roller tip rockers, headers, and thats about it.
i also have a holley TBI that im going to put new injectors in, and probably bore out the stock manifold to 2" to fit correctly.
tranny is 700r4 and i have stock gears, i think 273, in the rear.
i have in it now the comp cams extreme energy part# 12-256-4. its a hydraulic flat tappet. this cam crapped out on me with only 8k miles on it because i didnt know i had to add zinc to my oil!!!!!
any ideas on a nice torqy cam that will work good with what i have??
thanks!
'87 Static Slam is offline   Reply With Quote
Old 06-25-2010, 02:44 AM   #2
spinem
haha, ford guys...
Re: Cam Suggestions???
go to lmc.com and look at their smog legal cams. Get the specs and look at another dealer for cheaper!!
spinem is offline   Reply With Quote
Old 06-25-2010, 08:35 AM   #3
big10ratrod77
big10ratrod77's Avatar
http://www.summitracing.com/search/D...?Ns=Rank%7cAsc
here are some computer compatable camspic what you like but i would recomend still getting a custom built chip for every thing thats done to your truck just to make it run better overall.
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 06-25-2010, 01:19 PM   #4
'87 Static Slam
oh yeah, i do already have a jet stage 2 chip from jegs in the prom.
Old 06-26-2010, 12:10 AM   #5
datguysaL
i think comp cams offers that service, you juz call them up and tell them what u have and what u want and theyll give u the best set up for what u awready have..
datguysaL is offline   Reply With Quote
