Old 06-24-2010, 03:46 AM   #1
beebster
beebster's Avatar
Location: Aurora,Il ..born,raised and still live in the same house
front clip removal
on the front clip removal, exactly how many bolts are there and where are they located?
when i say front clip, i mean the two fenders and bumper all removed as one unit.
i've noticed some guys remove the "front clip" to make installing the motor or motor/tranny combo easier.
two guys removing it, with one hand each on the wheel well and one on/under the bumper.
I love stock!
Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine)
For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL
beebster is offline   Reply With Quote
Old 06-24-2010, 08:27 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: front clip removal
the bumper isn't hooked to the front clip.
2 fenders, fenderwells, core support and grill, and the hood with hinges.
Its been a while since I've done this... bit I think there's the nuts under the core support to the frame, 1 bolt in the upper rear of each fenderwell, 1 or two bolts per side in the lower rear fender, and then after removing the cowl, there's one or two bolts per side in there.
Then under hood, rad hoses, trans cooler lines (if an automatic) battery cables, and unplug the harness from the firewall.
I think thats it
Old 06-24-2010, 10:57 PM   #3
beebster
beebster's Avatar
thanks longhornman!
It might just be easier to leave em on and put the motor/tranny in like everybody else. ha ha
I love stock!
Old 06-24-2010, 11:02 PM   #4
leddzepp
Moderator
leddzepp's Avatar
FAQ has a good write-up on all the bolts that need to be removed.
I removed my entire front clip: hood, inner fenders, outer fenders, grille, rad support. Left it together as one unit. This way all of the sheetmetal gaps are maintained when reassembled. Here are some pics:
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 06-24-2010, 11:29 PM   #5
chevyblazer
chevyblazer's Avatar
awesome clean clip
cucharitas customs
chevyblazer is offline   Reply With Quote
Old 06-25-2010, 12:14 AM   #6
beebster
beebster's Avatar
Beautiful!
so it's everything minus the bumper (and bumper brackets).
I love stock!
Old 06-26-2010, 03:01 AM   #7
leddzepp
Moderator
leddzepp's Avatar
I also had to remove my lower steering shaft due to leaving the inner fenders attached.
