Old 06-24-2010, 06:33 AM   #1
FL71C10
How do you identify posi rear end
How do I tell if my rear end has positraction?
My spid label is missing.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 06-24-2010, 07:09 AM   #2
kacz81
kacz81's Avatar
Re: How do you identify posi rear end
Use a floor jack to get both rear tires off the ground and spin one tire if both rear tires move foward you have posi if one tire moves forward and backward you have one tire fire
kacz81 is offline   Reply With Quote
Old 06-24-2010, 07:52 AM   #3
FL71C10
Thanks!
Old 06-24-2010, 08:34 AM   #4
cdowns
cdowns's Avatar
from factory at the fill hole there is a plastic tag on it saying its posi
a good thing is to pull cover drain clean and freash clean new gear lube and at that time u can tell 4 sure
Old 06-24-2010, 02:34 PM   #5
raycow
Jack one rear wheel off the ground. Put the transmission in neutral and the parking brake off. Now try to turn the wheel. If you have posi in working condition, the wheel will be difficult or impossible to turn. If it turns easily, you have an open rear or a dead posi.
Ray
raycow is offline   Reply With Quote
Old 06-24-2010, 02:47 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
Stomp on the go pedal and see how many black streaks are left behind
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-24-2010, 03:13 PM   #7
Number98
Prestige Worldwide
Number98's Avatar
This test gets my vote....
Number98 is offline   Reply With Quote
Old 06-24-2010, 06:44 PM   #8
68longhorn
68longhorn's Avatar
agree with above, its the most fun. But the best way is to take the cover off and look for clutches.
68longhorn is offline   Reply With Quote
Old 06-24-2010, 07:10 PM   #9
tonypaul
tonypaul's Avatar
Take off the cover to find out for sure... Unless you have a full spool, both wheels may not nessarly spin with the tires in the air method. If you have a limited slip diff, it takes one tire to start to spin and then the clutches ingage and then both start to spin. "Posi" is a word that get threw around alot, I would recommend doing some research on your truck and maybe on the internet to truey idenify what type of diff you have...
tonypaul is offline   Reply With Quote
Old 06-24-2010, 07:32 PM   #10
FL71C10
Does someone have a picture of a posi gear set vs a regular gear set? Do I just take off the back cover?
Thanks!
Old 06-24-2010, 10:30 PM   #11
trusty72
trusty72's Avatar
open diff will be the ring gear with 2 small spiders gears and a pin thru the middle, posi with be encased with no gears showing other than the ring and pinion
1972 super cheyenne
1970 Suburb
trusty72 is offline   Reply With Quote
Old 06-25-2010, 06:58 AM   #12
LONGHAIR
In what kind of rear end?...I don't know of any factory 1/2 ton like that...
A Detroit Locker or a Gov-Lock for a 14 bolt FF, yes...but you are going to see spider gears in a 1/2 ton "Posi" too, there will be springs between them, but you can still see them.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-06-2011, 11:14 PM   #13
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
You bring back memories of a funny mishap I had when I just got my old 65 back up and running.
I didn't know I had a posi or limited slip. - It was a new rear-end.
Also just put a new high perform 327 in it.
My brother in law helped me get it all back together and his shop.
Just fired it up, and it had such a cool lope.
It didn't have an air filter, he said he might have one that would fit out back behind his shop. Yep it fit.
So I backed out of his driveway to take it for a spin, and he hand signaled for me to peal-out.
I knew this truck pretty well, and knew I could start off in second with the rpms up. So I revved it up and dropped the clutch.
I pealed off screaming down this little neighborhood street, smoke roaring out from under the fenders. Honestly, I was pretty much holding on. The throttle got stuck open. I had to shut the key off because it was screaming wide open. People came out of their houses. A burnt rubber smelling cloud slowly drifted away. As it cleared up, I could see two wide squirrely black stripes all the way back to his house. They didn't wash away for many months.
66 C20 Service Truck:
Old 01-06-2011, 11:25 PM   #14
Navy Mechanic
Navy Mechanic's Avatar
This is definitely the preferred method!
"Once a Chief, always a Chief!" MCPO (ret)
03 2500HD- 'Daily driver'
67 Short Fleet- 'Drivable project!'
11 Malibu LTZ- 'The Wife's ride'
Navy Mechanic is offline   Reply With Quote
Old 01-06-2011, 11:30 PM   #15
jakeblues652
jakeblues652's Avatar
just make sure you look in the mirrors and make sure theres no cars with pretty lights behind you
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 01-06-2011, 11:37 PM   #16
Hart_Rod
Hart_Rod's Avatar
Thanks!
Eaton posi pictures...
Hart_Rod is offline   Reply With Quote
Old 08-02-2019, 11:31 PM   #17
Christian Car
I tried this on my 72 Chevy c10 a few times. I sometimes left one track (right tire) and other times I left two tracks. When I left two tracks, the left track was very faint. what does this mean? I have no tag on my diff. Please help. Thank you.
Christian Car is offline   Reply With Quote
