Old 06-24-2010, 10:35 AM   #1
alden
alden's Avatar
best way to remove a stripped door handle/window crank bolt?
I've got two bolts giving me issues, on one door it's the inside handle, on the other door it's the window crank; both are stripped and won't budge a bit. I bought an ez-out kit but it doesn't look like I can get any of the bits in due to the bulky drill and the short nature of the bits. Any advice how I can get these things off?
Thanks!
-Alden
alden is offline   Reply With Quote
Old 06-24-2010, 12:40 PM   #2
OrrieG
OrrieG's Avatar
Re: best way to remove a stripped door handle/window crank bolt?
Are they the screw that holds the handle to the splined shaft? On small screws I have drilled the center with a small bit then drove the next size in to the hole and used it like an easyout with vice grips. It sacrefices the bit but gets it out. I seem to recall driving a nail into a small hole once too.
OrrieG is offline   Reply With Quote
Old 06-24-2010, 12:55 PM   #3
alden
alden's Avatar
yeah their those little screws that used a hex bit to remove, I'll give that a shot. My primary problem is the lack of room to fit my drill in but I'll see if I can't get a longer bit.
Old 06-24-2010, 03:18 PM   #4
OrrieG
OrrieG's Avatar
look in the electrical section at lowes.etc, they have long bits and extensions for fishing wires, I have a couple. If its a recessed hex, try a torx driver a little larger if you have one.
Last edited by OrrieG; 06-24-2010 at 08:42 PM. Reason: big fingers on small cell phone
