Old 06-24-2010, 10:59 AM   #1
Beatcoaster
69 Fleetside
Beatcoaster's Avatar
Power Steering Pulley
I am contemplating going from manual to power steering on my 69 chev. I have a double groove v-belt pully on the crank and waterpump. The alternator/water pump is using the outside groove as seen here:
My question is, does the power steering pump use the inside groove of the crank pulley or does it need a triple crank pulley and therefore I am screwed and have to buy a new one?
1969 Chevy C10 Custom Camper - "Frame On" Restoration
Blueprint 383 w/ 405hp@5200rpm & 441ft-lbs@4200rpm / Jegs TH350 w/2300 Stall / Drivelines NW 2-Piece Shaft / stock 3.08's / CPP 4" Drop Rear, 3.5" Modular Drop Front
Beatcoaster is offline   Reply With Quote
Old 06-24-2010, 11:29 AM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Power Steering Pulley
just the crank to pump.... no water pump on that
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 06-24-2010, 11:38 AM   #3
Beatcoaster
69 Fleetside
but will it line up with inside groove that I have open? Just the standard Saginaw keyway pump depth? I have no reference to look at or document since my truck is manual - that's my big issue. Thanks!
Old 06-24-2010, 11:44 AM   #4
Sinister
Between Trucks...
Sinister's Avatar
The PS pump pulleys vary. On my 350 with AC, it's supposed to be on the outer groove of of my 3 groove crank pulley. I put an aftermarket pulley on and it lined up with the middle groove where my AC belt is supposed to go. Still have to find a pulley that works. I would get a PS pump, bracket and pulley and mount it to see where you end up.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 06-24-2010, 11:48 AM   #5
Hottrucks
Hottrucks's Avatar
the inside of the pully is 4 3/4" from the face of where the freeze plug goes in
hope that helps
