Old 06-24-2010, 11:50 AM   #1
hotrod_991
hotrod_991's Avatar
Exclamation TH350C to TH350 non lock up
Ok so here is my situation. I bought a TH350C not knowing what it was and went to put it in my toy and that is when i found out that it will not work with my stall convertor because of the O-ring on the input shaft I would have to buy a lock up convertor and for a stall one im looking at around 500 or more. I could have my tired one rebuilt for less than that. So I was just talking to a tranny guy and he metioned that I could have the front pumps and shafts swapped from my old one to the 350C. Then i would be able to use my $700 paper wieght finally. Does anyone know how involved this is or any experience with it. Is it something I could do in my garage or do I need to pay the 300 to have a shop switch them? THanks guys and gals
"Buckle up I wanna try somethin!!"
"of course it will hold!, I welded it!"
1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint
hotrod_991 is offline   Reply With Quote
Old 06-24-2010, 02:47 PM   #2
blazer2007
Re: TH350C to TH350 non lock up
should be able to find a used one at a tranny shop for next to nothing
blazer2007 is offline   Reply With Quote
Old 06-24-2010, 03:21 PM   #3
ECU PIRATE
ECU PIRATE's Avatar
I just picked one up from my sister-in-law's uncle (2) weeks ago and I am already trying to sell it or swap it out....................
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 06-24-2010, 03:24 PM   #4
benoit454
Chris
benoit454's Avatar
I read the same thing online, pump change, fairly simple I guess unbolt and line back up, and chaning shafts not sure, I'd bet you'll be out a gasket kit time it's all said and done. I also heard some other minor internal changes had to be made, not sure of what nobody went into details. I know the gasket kits are like $40 on ebay for a 350 and rebuild kits go from $75-$150+ that included pretty much everything. I would ask the trans guy what it'd cost, I paid $60 for a used pump change last year, said he had to get some gaskets. If it's cheap enough let em do it, if not maybe have a reg. 350 rebuilt.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 06-24-2010, 06:29 PM   #5
hotrod_991
hotrod_991's Avatar
60 not a bad price I will havce to call around alil. the tranny guy wanted 300 for the change might be less if I reuse my old pump and shaft on the new one
Old 06-24-2010, 07:40 PM   #6
benoit454
Chris
benoit454's Avatar
Gotta remeber though I only had him change the front pumps, using one he had laying around, and he had to buy gaskets for it. I still think it should come in under a hundred, depdning on how involved it is.
Chris
GIT R DONE!!!!!!
