Dana 44
I can pick this up for 100 bucks,will it work for a spare for my 72 k10 and is it worth it for parts, ( the axles/spindles etc ) ratio is 3:07 according to diff tag other casting numbers are 445CF C36585 146CF and on the tube the numbers are 59 5AF 603454 my ratio in my truck ratio is 3:73 so the gears will not work,but for the rest of the spare parts ?? not a expert on this but are lots of these diffs still out there or did they change after 72.Thanks chisler
Re: Dana 44
I ran the material numbers and came up with 1974/75 as this being manufactured ,but the axle shaft numbers are different then the 1972 year would the axle shafts /spindles still work, To any one??
Re: Dana 44
The shafts will still work, just need to use a different seal. The shafts also use a bigger u joint..stronger= better.
Everything will work. $100 is a fair price. Does the pass side have a flat top knuckle? If so its deff worth $100.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
Re: Dana 44
OLDCHEV4X4, I picked up the diff, thanks for the info, I also took some more picks of the pass side and it is a flat knuckle on top(pretty sure)are these getting hard to find ,I now have a project LOL Thanks chisler
Re: Dana 44
Yes, that is a flat top knuckle.
You win!
