06-24-2010, 04:23 PM | #1 |
250 P/S help
Does anyone know if the p/s pump for a 250 is unique, as far as the alignment of the pulley with the other pulleys on the engine. I was installing my pump last night and after it was mounted, I discovered that the pulley does not line up with the water pump or crank pulley. Also, do I need a 2-groove alt. pulley? Any help would be appreciated. I know this is a common topic, but I tried the search function and could not find anything. The other issue I am having is my coolant temp is running hotter than it was with the old water pump pulley. Is there a big difference in the diameter of the pulleys? I was
thinking that the w/p may be turning slower if the pulley is larger in diameter.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
06-24-2010, 05:03 PM | #2 |
member #16
Re: 250 P/S help
There are some pics in this thread that may or may not help you. There have been pics posted of 250 6 cyl brackets in the last week ,but I cant find them.
http://67-72chevytrucks.com/vboard/s...d.php?t=405291 .
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
06-24-2010, 05:40 PM | #3 |
Re: 250 P/S help
I'm sure you will get many people here willing to help you. There are several different power steering set-ups for the inlines, which is why it's best to get a complete set-up including all pulleys and brackets from the same engine. That said, they are going to get more and more uncommon as time goes on. I'm pretty familiar with 2 of the set-ups off of Nova's ('74 with a/c and '72without). The one without a/c runs on the 2nd groove, and requires a 2 groove pulley on the alternator. The one with a/c runs on the 1st groove, and does not require a 2 groove alternator pulley. There are some set-ups that have a wide space between the grooves on the pulleys, so they don't require a 2nd groove on the alternator.
Regarding your overheating, the 2 groove water pump pulley that I used was actually a little smaller. Is it possible that you have a thermostat issue? I'll be more than happy to take some pictures or help you with part numbers if you want. But remember, there are different set-up, so that means different part numbers.
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
06-24-2010, 05:49 PM | #4 |
Re: 250 P/S help
This isn't mine, but it's a good picture of the power steering and alternator.
06-24-2010, 06:00 PM | #5 |
Active Member
Re: 250 P/S help
Heres some pic of mine and couple of others I'm not sure who they belong to that I've downloaded. Notice none of them are the same. Over the years people have added p.s. and changed pulleys, etc. As mentioned above the best thing to do is to remove them from a vehicle that had it from the factory to get every thing to match up. It may take so junkyarding and flea marketing to find all of the parts.. Good luck.
06-24-2010, 08:51 PM | #6 |
Re: 250 P/S help
AFAIK, there is nothing special about the inline pumps, but there are a bunch of different mounting brackets, which vary by year and application. I have found it is usually best to get the complete front end setup off a car engine, as these are much more common than truck inlines with PS.
Ray Last edited by raycow; 06-24-2010 at 08:57 PM. |
06-25-2010, 09:35 AM | #7 |
Re: 250 P/S help
68gmsee, my brackets are the same as the ones in the 3rd pic you posted. The brackets
all bolt on fine, it's just a pulley alignment issue I'm having. The pump pulley is too far forward to line up with the other pulleys. That is why I asked about the pump being unique to an inline six. Maybe the pulley is specific to an inline? I'll pm the member I bought it from. Thanks.
06-25-2010, 09:37 AM | #8 |
Re: 250 P/S help
NC67chev, I measured my 2-groove pulley and it is slightly smaller than the original, like you said. I will replace the thermostat and see if that is the cause. I think you're right, because last night on the way home from work, it did not heat up, but this morning it did it again. Thanks for the tip.
06-25-2010, 03:29 PM | #9 |
Re: 250 P/S help
How much is off is the water pump pulley from the PS pulley? Do you think it's off by about 1/2 inch?
Feel free to take/post some pictures and measurements. Or better yet, post some pictures of measurments. I'm betting that you need a water pump pulley with the extra space between the grooves in order to make your set-up work. Something like this one:
06-25-2010, 03:48 PM | #10 |
Re: 250 P/S help
I was wondering the same thing, but that would mean I would have to change the damper as well. I will see if I can get some pics this weekend and post them with the measurements. I would rather find a different pulley for the p/s pump than to change the water pump pulley and damper, but I may have to go that route. Thanks again for the info.
06-25-2010, 07:45 PM | #11 |
Active Member
Re: 250 P/S help
How far off is it? If it's minimal you can shim with washers. That's what I did on my other truck when the pump was off by about 1/4".
06-25-2010, 08:30 PM | #12 |
Re: 250 P/S help
Here's the original setup on my 71 SWB.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
06-26-2010, 11:28 AM | #13 |
Re: 250 P/S help
68gmsee, the brackets I have are different than yours, they will not allow the pump to move far enough back to line up due to the type of bracket. I think I need a pulley with a different offset to make it all line up.
06-26-2010, 02:31 PM | #14 |
Active Member
Re: 250 P/S help
The pic doesn't show a "straight line" shot so it's hard to tell how far off you are.
If I were you, I'd try to locate the correct brackets for your engine to mount the alternator. I got mine from the dealer but that was about 15 years ago. I have seen them on the some junkyard vehicles also, so that may be another option. |
06-28-2010, 09:26 AM | #15 |
Re: 250 P/S help
68gmsee, those are not my pics, Mt Man Chad posted those. My brackets are the same as yours. My p/s pump pulley is a single groove. Can you get a p/n from your p/s pulley?
I think if I get a 2-groove pulley for the pump, that would solve my problem. Thanks.
07-17-2010, 09:11 PM | #16 |
Re: 250 P/S help
last pic from nc67 chevy that one works without the double alt pulley,like the earlier one that just runs off the water pump .Wow this is a nightmare gettin parts for this very hard to find i got lucky and found a wide pulley and put this in my 67 nova but had to space the fan 1 inch to clear the p/s pump pulley.If you got this stuff or know where to get it and you may need it grab it! Its rare now! Thanks to all who posted this stuff very helpful timbuk
65 sbfs 65lbfs 65ccsb 65BUS 68GMC and many cars from the 60s |
07-19-2010, 09:48 AM | #17 |
Re: 250 P/S help
Does anyone know if the shaft length is different between the early pumps and the late pumps? Maybe that is why I am having the pulley alignment issue? Thanks, Mark.
07-19-2010, 11:11 AM | #18 | |
Active Member
Re: 250 P/S help
I did find a pn but it's hard to make out the last 2 numbers or letters. I got this pulley and pump off a newer vehicle. The first 7 digits are pretty clear: 458531A?? The last 2 could either be AA, RA, AR or something similar One thing you need to remember is that the pulley is press fitted in the shaft and can be moved slightly. It is a tight fit and the only way I know to remove is with a special tool and air compressor. http://www.getahelmet.com/jeeps/maint/steeringpulley/ |
07-19-2010, 01:31 PM | #19 |
Re: 250 P/S help
Thanks for getting that number, I will check it against mine and see if it's the same. I know mine has a number on it, but I don't remember what it is. Yeah, somebody else told me about the special tool for removing the pulley. If it comes to that, I will just see if I can get another pump with the correct pulley. Thanks again for the info.
06-15-2017, 10:39 PM | #20 |
Re: 250 P/S help
I'm bringing this thread back from the dead. It doesn't look like 70STOVEBOLT got any resolution here. I did see a 2013 thread where he got a different pulley from a boardmember.
I have the same problem. But I think I have it figured out. I have 3 complete sets of Inline 6 power steering pump brackets, 3 pulleys and two pumps. My first big problem was just assembling the erector set that makes up the bracket set. I have the correct spacers and bolt lengths...but what a pain in the ass. Here is a picture of how it turned out. No so great. None of my pulleys will line up and the pump is a bit crooked(the picture makes it look worse). Here is what I have found to correct the problem. I ordered these 2 pulleys: http://www.ebay.com/itm/271974107654 and http://www.ebay.com/itm/271974107973 The first one cross references to a GM#3834720 looks just like a 38810 from Classic Performance. The second one looks like a GM#3770509 or 38809 from Classic Performance. I also saw this page with an AG-515 that says it is a pulley that is offset one full groove. I think that would work for me. - http://www.hotrodhardware.com/index....84/prd2984.htm |
06-15-2017, 11:09 PM | #21 |
Re: 250 P/S help
Found this other thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=612725 70shortstep got a pulley from a board member that looks like it works right. Looks to be a 3834720. But, they don't list the part number in the thread. |
06-16-2017, 10:33 AM | #22 |
Re: 250 P/S help
I purchased this bracket for my 292 it is very well built and solid what I liked is that it allows for forward and back adjustment of the pulley for alignment. My friend just purchased one for a 250. This is a link, I know its pricey but it works also look into what type of water pump you have before ordering as I believe he has two or three models for the 250.
http://www.ebay.com/itm/10002-153-19...hSDYe-&vxp=mtr |
06-16-2017, 11:51 AM | #23 |
Re: 250 P/S help
I don't really need more brackets. I have 3 sets of factory brackets. I just need the right pulley(I think).
I had seen those for sale before I started accumulating factory style brackets. I did just discover this morning that one set is slightly different. I'll take pictures and post later. I just got done blasting everything I have, so I can get everything painted. |
06-16-2017, 02:02 PM | #24 |
Re: 250 P/S help
Here are some of the parts I have...besides what is mounted on the engine. Top Left - I don't know the part Number - One is on the engine in pic above Top Right - 343301 - One is on the engine in the pic above Middle Left - 354527 Middle Right - 355789 Bottom two - All the same. I don't know the part number but I have another on the engine. If I use the two in the middle row instead of the two in the top row, It will place the pump slightly further back on the engine. I'm mainly just posting this here for reference. I have looked at old messages and there is tons of info already out there...but not many part numbers. |
06-16-2017, 11:07 PM | #25 |
Re: 250 P/S help
Jason, I forgot about this thread. I ended up buying an aluminum pulley off of eBay from a company called CVF racing, their p/n is CVF-SBC3PS. The one I bought from blkcorvair was actually for a 283 and I sold it to chewychevy. I have since put a 402 in the truck but I still have the 250 p/s setup. The brackets look like your middle row and bottom left in your pic above, plus another bracket that runs from the rear of the pump to the block by the lower alternator bracket. I can take some pics tomorrow and post them if you want.
