Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-24-2010, 05:43 PM   #1
68laydout
Junior Member
68laydout's Avatar
Got a free Super Powershot plate system - advice?
Any advice? Never ran nitrous before. I was thinking go for the 150hp shot? Crazy? I've got an older sbc thats freshly built. Thumpr cam(noise maker), .60 over, stock heads, Performer carb and intake. It came with a bottle opener and heater too.
Would greatly appreciate any advice. Cory
68laydout is offline   Reply With Quote
Old 06-24-2010, 05:59 PM   #2
grinch4om
dang its hot
grinch4om's Avatar
Re: Got a free Super Powershot plate system - advice?
the best thing you can do is read! start small...nitrous is safe as long as you dont lean out. fuel system needs to be up to snuff...find someone in your area that is doing it
grinch4om is offline   Reply With Quote
Old 06-24-2010, 11:23 PM   #3
Captainfab
60-66 Nut
What type of pistons are in the engine. Cast, hyperuetectic, or forged? That will determine how much you can spray safely. It will also be beneficial to have a timing retard, so that the timing can be retarded when the N2O is injected.
Old 06-25-2010, 07:19 AM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
For 150 I would start with 6 psi on fuel and take 6 degrees of timing out . Ease into it and add a degree and ease the fuel pressure down to 5.5 and/or work your way up on bottle pressure . Here is what NOS called for :
Your combination may vary. These guidelines are suggested as a safe starting point in tuning.
H.P Jetting Fuel Quality Ignition Timing Spark Plug
Level N20 / Fuel Heat Range
100 47 / 53 92+ octane pump gas 2° ignition retard Standard
125 55 / 61 92+ octane pump gas
with octane booster
2 to 4°
ignition retard
Standard to 1 heat
range colder
150 63 / 71 92+ octane pump gas 4 to 6° ignition retard 1 to 2 ranges colder
with octane booster
175 73 / 82 or 100+ octane (R+M/2) 6 to 8° ignition retard 2 to 3 ranges colder
racing fuel
*At the 73/82 (jets not included in kit) jetting level, the Super Powershot nitrous solenoid is flowing near maximum
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 06-25-2010, 08:19 AM   #5
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
or you could sell it all to me so I can put it on my caddy...Ive been looking for one seems the plate set ups are getting hard to find with the efis alot of the new systems are dry and use the computer to correct the lean factor.....
DO NOT LET IT LEAN OUT one sneeze and bad stuff happens expecially if your running a Holley ( takes out the power valve) so do all your home work then find someone to work with...NOS is not flamable but pluming the extra fuel pump and running the lines needs to be neat and safe
Hottrucks is offline   Reply With Quote
Old 06-25-2010, 10:17 AM   #6
68laydout
Junior Member
68laydout's Avatar
I appreciate all the responses! Great advice.
Captainfab - they are cast pistons
Old 06-25-2010, 10:34 AM   #7
swb85
On a budget like Fred Sanford
swb85's Avatar
I'm a nitrous guy too, my camaro and I are addicts.
Start small, don't go straight to the 150. Like said above, pistons are going to be the determining factor in HP limits. If you've got cast pistons, you're in trouble---don't go above a 100 shot. If they are hyper pistons, you can get away with up to a 150 with a good tune and correct ring gaps.
It's an old wivestale with nitrous that lean is to be avoided at all costs and rich is safe. You can absolutely burn stuff up if it goes real lean (it'll slow down before that happens), but almost all nitrous related engine failures are from either too much fuel, too much timing, or both. If you run it too fat, fuel will get pulled down into the ringlands.....and when that fuel ignites it'll lift the ringlands and you'll start getting oil in the chamber. Once that happens it cannot be saved, won't be long and you'll have pistons that look like they were hit with a blowtorch. Start small on the shot, be conservative with the timing and READ THE PLUGS to tune it.
Go to the nitrous section on yellowbullet.com and read read read. There are some very smart guys that are very helpful in there. Both Monte Smith and Steve Johnson (big time nitrous tuners) hang out in there.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 06-25-2010, 10:45 PM   #8
68laydout
Junior Member
68laydout's Avatar
Thanks man.
I really appreciate all the responses. I'm headed in the right direction now.
Old 06-26-2010, 03:41 PM   #9
djracer
djracer's Avatar
Your best bet is to call monte smith he is the NOS guru and he can point you in the right direction. but I would keep it small with cast pistons. 256-783-3418 He is the head tech guy for nos and a great guy. He sells some parts at a deal also.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-26-2010, 10:36 PM   #10
Hart_Rod
Hart_Rod's Avatar
Some great advice here. This is on my list of things to do.....
Hart_Rod is offline   Reply With Quote
