Old 06-24-2010, 10:41 PM   #1
AusTx68
AusTx68's Avatar
Fitting Rear Window Rubber
I purchased a rear window seal from LMC for my 68' large window. When I tried fitting the glass inside the rubber it didn't fit. The rubber seems too big for it to wrap evenly around the glass. Is this normal? I figured it would fit snug on the glass.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 06-24-2010, 11:16 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: Fitting Rear Window Rubber
You didn't strech it out did you. The glass should be just tight in the gasket.
I will set mine in the sun and they have all worked fine.
So the answer is yes it should fit tight with no gaps.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 06-24-2010, 11:21 PM   #3
AusTx68
AusTx68's Avatar
Yea that's what I thought. Not sure why this one is giving my problems. Guess I'll mess with it some more tomorrow.
Old 06-24-2010, 11:59 PM   #4
mstrav1973
mstrav1973's Avatar
I thought mine was big as well. I taped and roped it together and it ended up being perfect. I bought mine at LMC also.
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!!
mstrav1973 is offline   Reply With Quote
Old 06-25-2010, 12:07 AM   #5
AusTx68
AusTx68's Avatar
Matt
Taped it? I knew about the rope but where are you putting the tape?
Old 06-25-2010, 12:13 AM   #6
mstrav1973
mstrav1973's Avatar
Taped the trim in the corners so it wouldnt roll out. Only tape the top not the side where you cant get the tape out. Is yours a trim set up or no trim?
Matt
Old 06-28-2010, 02:11 AM   #7
AusTx68
AusTx68's Avatar
No mine is without the trim. I found the problem. It was that b.s. rubber I got from LMC. It was about 6" too long. After messing with it for 2 hrs I decided to purchase another from a local classic truck vendor. The new seal fit perfect! I'm returning the worthless LMC rubber.
