Old 02-16-2003, 11:56 PM   #1
KEH
Better late than never
KEH's Avatar
Clutch Slave Cylinder
I've seen reference to this in the shop manuals. My truck doesn't have one. I'm going from a 3 speed to a 4 speed trans., & I'm wondering if this is an upgrade I need.
1) what is it?
2) do I need one?
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 02-17-2003, 12:38 AM   #2
bigvinnie
bigvinnie's Avatar
If you're talking about 67-72 trucks, they didn't come with em (at least the 1-ton and smaller didn't) and you don't need one unless you're upgrading to a newer style trans and clutch...
Anyone know when they first appeared in chevy trucks? I'm guessing some time in the late 80s...???
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 02-17-2003, 12:43 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
A stock truck has a mechanical linkage. A steel rod that goes from your clutch pedal to the inside of your tranny which physicly disengages the clutch when you put your foot on the pedal.
On a newer set up, it works like the brake pedal. The pedal pushes a piston in a clutch master cylinder, which moves the fluid in a hose, then pushes the slave cylinder, which disengages the clutch.
The pros are;
lighter pedal presure
no linkages to mess with
Cons are
all custom fabbing to install in old trucks
cost of replacement parts
More dot 3 fluid to eat your paint when it springs a leak
Many old school ppl (like many of us on here) like the rod clutch for its simplicity. You can pop the hood and tell if it is all working properly.
Old 02-17-2003, 12:51 AM   #4
crazy longhorn
Fabricate till you "puke"
Some of the older pick ups had hyd clutches (early 60s)....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-17-2003, 12:53 AM   #5
KEH
KEH's Avatar
Good deal...one less thing to do.
Thanks guys.
