Old 02-16-2003, 11:57 PM   #1
72gmcshorty
72gmcshorty's Avatar
4 core rad question....
How much coolant fluid does a 4 core rad hold? In litres please. is it safe to keep just water in mine until i get my truck drivable? i've got the motor started but i don't drive the truck yet. I don't want to have to drain coolant if i don't have to. Know what i mean?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 02-17-2003, 12:48 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Can't answer the first question...but if it gets below 32 degrees...or zero for you guyd in metric land, then I'd drain it A.S.A.P. Froxen water does nasty things to a $4000 lump of iron.
Old 02-17-2003, 01:56 AM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
Two problems with straight water. First is freezing, second is corrosion. Your engine's water jacket will rust, the water pump will rust, and the radiator and heater core will corrode. Put two gallons of antifreeze in, and when you have to drain the coolant later you can capture and re-use it.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
