Old 06-25-2010, 02:34 PM   #1
Lippyp
English Chevy Owner
Lippyp's Avatar
Two important questions
Before I dive into changing the intake and HEI tomorrow I have two important questions.
First Important (but dumb!) Question: Am I right in thinking that number one cylinder on a SBC is the front one passenger side and then they go front to back and then back to front on the other side (i.e. round in a circle)?
Second Important (but dumb!) Question: If I am using RTV sealant instead of the rubbber end seals on the intake what size bead of RTV do I need to use?
I'm sure once I start stripping it down I'll be running inside with more questions and cursing the time difference as most of you guys will still be in bed.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 06-25-2010, 02:38 PM   #2
QKENUF4U
QKENUF4U's Avatar
Thumbs up Re: Two important questions
firing order pic attached
i put a 1/4-3/8" wide/1/4-3/8" thick bead on the block after cleaning every thing spotless (no oil/dirt/grime)
QKENUF4U is offline   Reply With Quote
Old 06-25-2010, 02:40 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
Edit: Already answered. DOH.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 06-25-2010, 02:41 PM   #4
BIG69GMC
BIG69GMC's Avatar
actually #1 cylinder is on the driver side at the front of the engine and #2 is at the front of the passenger side (back and forth) so 1,3,5,7 are all on the driver side going to the back of the engine and 2,4,6,8 on the passenger side from front to back of the engine. As for the silicone, you want to use like a 3/8 size bead to make sure it seals good, with out all squeezing out so it forms a "gasket". Hope this helps!
BIG69GMC is offline   Reply With Quote
Old 06-25-2010, 04:06 PM   #5
71tahoe
71tahoe's Avatar
In France, which side is passenger and which side driver?
71tahoe is offline   Reply With Quote
Old 06-25-2010, 04:34 PM   #6
BIG69GMC
BIG69GMC's Avatar
lol! i hope the driver sits on the driver side, unless he is driving the passenger on the passenger side lmao!!!!!!!!!
Old 06-25-2010, 04:40 PM   #7
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
before you gently put the intake on let the RTV set for 15 min or so ..also if you can wait till the next morning to start it you'll be better off as it has time to cure abit before getting hot and oilly......
personally I like to use the gasket for the front and rear...putting a dab in eash corner of where the block, intake and heads meet...also use Fel Pro or do it again...
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 06-25-2010, 04:42 PM   #8
1-PU70
1-PU70's Avatar
What I like to do is take a center punch and make several dimples on the block under the bead of silicone so when it dries it doesn't slide out. And like said before make sure everything is squeaky clean. You can use some brake or carb cleaner on a rag.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 06-26-2010, 02:53 AM   #9
Lippyp
English Chevy Owner
Lippyp's Avatar
Thanks for the info guys, I have a felpro gasket set which does have the rubber end seals in it so I'll have a look when I get the old intake off. The gasket does have the centre hole for the heat passage doodad but also comes with a metal restrictor plate with a hole in. Should I be using this or leave it open. The new manifold is a Performer EPS. I have a tin of gasket remover and plenty of brake cleaner.
The truk is in the UK not France and its a standard US truck so I get to sit near the pavement (sidewalk) and look at all the pretty girls! In France it would be on the right side, just us old fashioned countries that drive on the left (right, sorry correct) side of the road!
I'm going to label the plug wires with some masking tape and numbers before I take the dizzy cap off so I can wire the new one up right.
Looks like its gonna be a nice day, temperature forecast to be hitting 26/27 degrees C so I shall be working outside with plenty of sunscreen on in the hope of getting a tan.
Phil
'67 C10 long fleet.
Old 06-26-2010, 07:46 AM   #10
Hottrucks
Hottrucks's Avatar
that little tin pplate is for an intake heater....personally I block them I like to keep the intake cool..but it takes a bit longer to warm up
