Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-25-2010, 04:00 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Rear end Questions
I have a 85 that will eventually be a street/strip machine with more emphasis on the strip but I still want to be able to drive it on the street occasionally. I am thinking 9" rear but don't know what to use for the carrier. Spool or locker? If locker, detroit the best? I owned a Rockcrawler with a detroit and it was bulletproof, are they just as good for the strip?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 06-25-2010, 05:09 PM   #2
team39763
Re: Rear end Questions
I run a Eaton limited slip(clutch type posi). I heard the Detroit locker is nearly bulletproof, but a bit aggressive for the street. The Detroit Tru-track(sp?) is nice but doesn't stand up to much abuse from what I've read and isn't rebuildable like the Eaton unit. My truck doesn't make much power and it isn't really fast, but it has been put through the abuse of drag racing with slicks. So far I haven't had any problems with the Eaton unit. Many of the new body style truck guys choose the Eaton also. I had one in my NBS truck(2000 Sierra) that took a bunch of abuse and it worked flawless.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 06-25-2010, 05:12 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
You don't want to run a spool on a street/strip truck.
Strip only - run the spool.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-25-2010, 11:33 PM   #4
Captainfab
60-66 Nut
I would go with the Detroit. As already mentioned they are a little aggressive on the street, but if you've been into rockcrawling you already know what they're like
Old 06-26-2010, 10:10 AM   #5
softballnrd27
I have dealt with the detroit before and it wasn't bad once you learned what it was going to do. I got a guy that I work with that has a low 11 sec Malibu that he races and he runs a detroit in a 9" with a 5spd and a nitrous big block. Now I just need to find out how wide I need my readend so I can find a housing for it. Next decision, trailing arm rear suspension or caltrac and leaves.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 06-26-2010, 11:49 AM   #6
ripdog28
ripdog28's Avatar
I love my locker, even when sideways itll go straight and not spin out if youcan drive of course. Not to annoying because the motor is louder then the locker when turning.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 06-26-2010, 03:49 PM   #7
djracer
djracer's Avatar
If you run after market axles and a spool you can drive it on the street a little. The detroit is really expensive and will still be locked most of the time. I would probably run caltracs if I was already leaf. With that said I am changing my son's 70 model to a trailing arm coilover setup.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-27-2010, 12:10 AM   #8
softballnrd27
I am going to get the suspension right before I do a real motor and I am really leaning towards the trailing arm system. I love the way your truck hooks DJ and that has me sold on the trailing arm suspension.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 06-27-2010, 12:12 AM   #9
softballnrd27
When going 9", can I get a housing from the junkyard and add some bracing and be good or do I need to go aftermarket like currie or moser?
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 06-27-2010, 12:22 AM   #10
djracer
djracer's Avatar
You can do a stock housing with bracing. That is what I just took out of my truck for a fab housing. I am gonna put my old one in my son's truck.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 06-27-2010, 12:10 PM   #11
68GMCCustom
was it a leaf spring truck?
Kurt -
Old 06-27-2010, 11:44 PM   #12
Captainfab
60-66 Nut
An '85 would be leafs........
Old 06-28-2010, 12:01 AM   #13
68GMCCustom
LOL...I guess so! I missed the year I guess.
Kurt -
Old 06-28-2010, 01:19 AM   #14
ripdog28
ripdog28's Avatar
IMO, stay leaf w/cal tracks. It would be easier to just go 4link if you wanted to get rid of the leafs.
69 c-10 BBC
Old 06-28-2010, 05:25 AM   #15
djracer
djracer's Avatar
Your truck should have come leaf if it didn't have coil spring rear as an option.
My son's 70 model is a chevrolet but it came with the leaf option.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 06-28-2010, 10:20 AM   #16
softballnrd27
It has leaf springs in the rear but I like the trailing arm suspension. I haven't made up my mind yet on which way to go.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 06-28-2010, 01:03 PM   #17
68GMCCustom
y'all will notice a couple of differences between the frames...that make the swap a little bit of a pain....lots of rivets to deal with to remove the leaf stuff and install the coil stuff.
Kurt -
Old 06-28-2010, 04:54 PM   #18
djracer
djracer's Avatar
I didn't have much trouble swapping my uncle 66 gmc. An 85 would be a tougher swap.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 06-28-2010, 10:49 PM   #19
Captainfab
60-66 Nut
Seems to me someone was working on a trailing arm/coil conversion for the squarebodies......might have been Porterbuilt?
Old 06-28-2010, 10:52 PM   #20
djracer
djracer's Avatar
Somebody does have a kit for the square trucks but I don't remember who.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 06-28-2010, 10:58 PM   #21
softballnrd27
CPP has a kit but it is $1700 dollars
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 06-29-2010, 01:23 AM   #22
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
I Have the CCP cross member I took it out and went Porter built and will never look back. It allowed me to have a fully adjustable trailing arm suspension and the ability to run my 5" aluminum drive shaft.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 07-12-2010, 09:45 PM   #23
chris mc bride
chris mc bride's Avatar
First you can run a spool on street as long as it just a saturday night specail or for rod runs.The only problem you will have is when turning slowly you will feel a little chatter in the tires.It just takes a little getting use to.
As for the hight priced after market housings.unless your going big on the power I would worry about them.You can either buy a junk yard unit shorten it your self,if you have decent fabricating skills(do some research there are tons of articles on it).Once you have new ends welded in you will be good to go.If you want you can spend some time very little money and fabricate some bracing across the back just like the high price units.
I know it sounds like a lot of work.It is but you get lots of rewards.Pride that you built it is number one. Probaly a few comment about it and more satistfaction of sayinf yea I did it my self.Plus you have more money to build more power to see if you can break what you built. Yea but you always push for more,beleive me 25 years of playing with this $hit has shown me this.
chris mc bride is offline   Reply With Quote
Old 07-15-2010, 12:23 AM   #24
dbmx66
if your gonna run a spool, youll need after market performance axles and c-clip elimnators.
dbmx66 is offline   Reply With Quote
