haha, ford guys...
An upgrade that everyone needs to do.
So after some extensive searching i found insufficient info on how to convert a single headlight through switch to relay conversion......sooo. I decided to wing it via the diagram attached....
Let me just say this.... WOW! Id say its a good 33% more efficient light out put! I bought some GE $8.xx usd halogens from walmart about 4 months ago and was never fully satisfied until now. They actually cast a slight blue even! (not excessive like some retarded honda) wooooooo hoooo !!! Yes, it is a huge cluster f*** of wires, but it gets the job done! ne whooooo... heres some pics!!! more to come in a few.. gotta switch to windows to upload.... [ATTACH][ATTACH][ATTACH] Last edited by spinem; 06-26-2010 at 04:25 AM. |
haha, ford guys...
Re: An upgrade that everyone needs to do.
Now I was talking about low beams being at least 33%+++... hi beams.... WOAH. I can blind the hell out of drivers hahahaha, but no really, i can see the entire road.
Problems I ran into: the back of the lights themselves, there are 3 tabs. I figured them to be the same size to be able to inserted inside a standard female connector. I was mistaken. They are waaaay larger, and this messed up my entire plans. SO i simply reused the stock connectors. I use the one with 2 wires for each terminals on the drivers side (furthest away from the battery)..... i connected both wires, then soldered to a large 10ish g wire and ran to relays..... as for the passenger side, i used the single wire, dual around stock "harness". (closer to battery, singel wire okay due to only a ft of travel) The + to relays is 0g to fuse, 8g to relays.--0gwire was free, fuse was 12.oo usd backn the day. Grounds for relays: 8g (same exact leanth for balance)--Free, found at junk yard on ground, tested fine on voltometer. Relays are 20/30 Bosch/tyco (tyco makes bosch) Fuse is a 40 glass tube. Hope this inspires some people!!!! --------night pics soon to come----------- Wire all around: 10g??? fuel proof, 1200watt stable---Free, had for years. |
I never did it to single lights, but when I swapped 89-91 front end I did the high beams with a relay, and with both lights on, you could see the difference. These were just plain ol lights, but the high beams where almost white, the low beams were yellow compared to the highs. Gonna do the relays on both low/high soon as I get my truck close to work on it.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
#4 | |
haha, ford guys...
GM Addicted
damn thats alot of wires sitting there you should run a power block somewhere and hide it all or something if it where me i would, You back in visalia or in fresno still??
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
#6 | |
haha, ford guys...
Ive been kickn it out here n Anaheim accually |
haha, ford guys...
Lows
highs |
GM Addicted
Looks good and wtf you doing in Anaheim your never in visalia hahaha
Member of the longbed union.
man you can get a power block from the auto store for like $10. And I hope thats not speaker wire your using for hot wires. It's kinda hard to tell, but the outer coating will heat up and melt. Just giving you warning. The lights look really good though.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#10 | ||
haha, ford guys...
My way, it is attached to the batery box, close + source and secure. Why would i run a + from batt, to a dist block, just to run the relays to the + off that!? it make no sense. NO NOT SPEAKER WIRE., its 8g ground cable /w/ copper tabs. Last edited by spinem; 06-28-2010 at 01:49 AM. |
GM Addicted
[QUOTE=spinem;4062350]hahaha im chilln with mickey, donald, goofey, the whole gang!!!
Well you best be getting at cinderella and checking them fluids ahahaha, dont get caught getting goofey with goofey!
you dont have to run a power block. I was just suggesting it to clean up all the wires a little. But hook it up however it gets the job done.
#13 |
where did you mount the relays?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
#14 |
Good job Spinem. Here's a link to a similar headlight upgrade.
http://www.73-87.com/7387garage/exte...y81-87Quad.jpg |
#15 | |
haha, ford guys...
[quote=54Caddy;4062389]
on the siide of my battery box |
