06-26-2010, 08:26 AM | #1 |
original motor-best oil type
time to change the oil in my 50' gmc 228 its original with 63,ooo miles a valve job runs sweet with some blow by . if you you guys got some suggestions on wieght or synthetic or non that would be great. thanks in advance!
06-26-2010, 12:08 PM | #2 | |
Re: original motor-best oil type
Napa sells an oil specifically designed for these engines. Not sure about the weight but that can be found out easily enough.
View my truck's story here: http://67-72chevytrucks.com/vboard/s...d.php?t=402996 |
06-26-2010, 12:10 PM | #3 |
Hollister Road Co.
I would use a diesel oil, something like Shell 15w-40 Rotella T or
Shell Rotella T6 Full Synthetic 5W-40 |
06-26-2010, 12:21 PM | #4 |
It doesn't matter if you run synthetic or not, but the oil has to have ZDDP in it which is a zinc additive. Zinc was eliminated recently in most oils because it shorten the life of catalytic converters.
Running without zinc will destroy the valve train in a flat tappet motor. I run synthetic in everything I own, and pretty much wouldn't run anything else. I know back in the late 60s, early 70s, I ran Valvoline 30wt non-detergent in my '47 216, and 49 Jimmy with a 270. The topic of oil can get pretty controversial — just make sure you have zinc. |
06-26-2010, 12:32 PM | #5 |
Valvoline VR1 Racing oil has zinc in it and usually comes in either 10-30 or 20-50 weights. Autozone usually carries it. Another option is to use you favorite oil and just put in an additive like STP, which has zinc.
06-26-2010, 12:43 PM | #6 |
Good to know, thanks guys!
06-26-2010, 04:18 PM | #7 |
Not to hijack, but is anything different on the 55-59 235's? I haven't driven it at all since I changed it so if I need to change it out again I can, but I just went with a 5W-30 Valvoline oil mix.
What about transmission/rear-end, anything special required to accommodate the old mechanicals? |
