Old 06-26-2010, 03:36 PM   #1
Chief Bail
Chief Bail's Avatar
No power after valve adjusment
Ok all I just did a valve adustment on my in line 6. Umm now it's sputtering and has no power. Did I snug them down to tight???????
HELP A BROTHER OUT PLEASE...
1979 GMC Sierra 15
1986 Danco Rollback 454 4spd
1986 Jerr-Dan Rollback 454 4spd
1978 GMC Jerr-Dan 454 Tonawanda 4spd FOR SALE
85 Chevy Wrecker 454 4spd AATAC
Always a Friend...Michael
Chief Bail is offline   Reply With Quote
Old 06-26-2010, 04:05 PM   #2
cdowns
cdowns's Avatar
Re: No power after valve adjusment
i'd loosen them up and start from step one in the service manual
Old 06-26-2010, 04:22 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Yep, sounds like it. There's a procedure to do them with the engine not running. I usually prefer to do them with the engine running.
What was the reason for the adjustment? Normally, once you adjust them they should stay in place unless the rocker nuts get loose. If they were making clicking noises, you probably should replace them. If you tightened them to get rid of the clicking, you probably bottomed them out --not good.
68gmsee is offline   Reply With Quote
Old 06-26-2010, 05:12 PM   #4
vectorit
What?
vectorit's Avatar
Hydraulic or solid lifters?
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 06-26-2010, 08:18 PM   #5
68gmsee
Active Member
68gmsee's Avatar
Unless the cam and lifters were changed, they're all hydraulic from the factory.
Old 06-27-2010, 10:02 AM   #6
Wrenchbender Ret
You probably have varnish built up in the lifter. Readjust them. Back the adjustment up till the rocker has a little play in it & tighten it down 1/4 turn.
Wrenchbender Ret is offline   Reply With Quote
Old 06-28-2010, 12:05 AM   #7
beebster
beebster's Avatar
Location: Aurora,Il ..born,raised and still live in the same house
start it up and start with the first one. Loosen it till it "clacks" then tighten til the "clack" is just barely gone,then 1/4 turn.
Then next one.
clack= flopping around
I love stock!
Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine)
For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL
beebster is offline   Reply With Quote
Old 06-28-2010, 11:46 PM   #8
Chief Bail
Chief Bail's Avatar
Ok im going with some solid lifters in this puppy. Gonna run this 6 banger till im ready for the BIG DAWG.....
Thank You all for your help.
1979 GMC Sierra 15
