06-26-2010, 04:32 PM | #1 |
Alright Alright Alright
What are some healthy oil PSI readings?
I have been keeping an eye on my pressure gauge lately and I notice that when im on the highway, im reading about 40-45 psi. When I come to a stop (feeder road) my psi drops below 10 and this is after a 30 min highway drive an 200 degree engine temp. The engine doesnt smoke or burn oil and runs like a top. What do you think?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
06-26-2010, 04:48 PM | #2 |
Re: What are some healthy oil PSI readings?
nothing to b alarmed at thats pretty normal for an old chevy
06-26-2010, 04:58 PM | #3 |
10 PSI FOR EVERY 1000 RPMs WHEN WARM IS O-K. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
06-26-2010, 05:44 PM | #4 |
Old Duffer
It's not broken....don't fix it.
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
06-26-2010, 05:52 PM | #5 |
ya ill live by the 10psi per 1000rpm but ive NEVER had one drop to 10psi or less at idle.... maybe step up to a 20w50 weight oil and hope for the best.. it may run that way for 1 million miles or it may run that way for another 10miles... i personally wouldnt like it being that low.....
also whys your truck running at 200* ? |
06-26-2010, 06:05 PM | #6 |
Junior Member
Heck the gages in thes old trucks are not that accurate, even the cheap after market ones.
Some of the newer stuff is designed to run hotter than 200 degrees to meet smog requirements. All my engines seem to be happy running in the 180-200 degree range. As stated above 10 pounds for every 1000 rpms sounds about right. 10 pounds at idle would make me a little uncomfortable in an old engine, but not much. You could run 15-40 in the summer and something more like 10-30 in the winter. IMHO
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
06-26-2010, 06:39 PM | #7 |
try a quart of lucas in your engine,i run a quart of lucas to 4 quarts of 20w50 get 30 pds at idle.45 to 50 pds at bout 60,65.but i have a 4.3 in my 91.
06-26-2010, 06:54 PM | #8 |
Gone to greener pastures
Yep.
If it were mine I wouldn't even worry about it. You have oil pressure at idle, so things are getting lubricated. I don't know, but I've been told that some newer cars carry very little oil pressure at idle.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
06-26-2010, 06:56 PM | #9 |
If it's not making noise it's getting oil pressure. Run it.
06-26-2010, 07:48 PM | #10 |
The motor is about 6 years old. It runs great and has no engine noise. The plugs are also white.
06-26-2010, 08:14 PM | #11 | |
as for new cars running 200* thats apples to oranges comparing old to new.... only time ive ever had a car/truck run at 200 is when it was overheating (68 camaro-built 327, blazers- built 350's, 71 c10 - bb 402 in avatar living in phoenix, never seen 200* ever) i do agree that using the old guage really isnt gonna give ya a good indication of pressure.... personally i would up the oil to 20w50 (summer) and let it live its life happy and oiled... Last edited by QKENUF4U; 06-26-2010 at 08:14 PM. |
06-27-2010, 01:34 AM | #12 |
Mine isn't much better, mine's about 15psi at idle in gear (about 800 RPM's). Down the highway mine's about 40PSI as well.
With the A/C on high, sitting in traffic, in 100 degree temps, my truck stays around 190*. I think 200 is high for an old chevy. I had temp problems when I first installed my A/C (radiator was too small) and my truck ran like crap when it would spike to 200-205 degrees. New 4 core radiator and 190* T-stat and all is well
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
06-27-2010, 04:25 AM | #13 |
It'll Buff Out!
What Brand of Oil Filter are you running?
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
06-27-2010, 06:43 AM | #14 |
I am running a microgaurd filter. My thermostat is 195 degree.
06-27-2010, 08:09 AM | #15 |
Junior Member
I like to run a 180 degree thermostat in all of my GM trucks.
06-27-2010, 11:42 AM | #16 |
06-27-2010, 01:57 PM | #17 |
It'll Buff Out!
I run a 160 myself with a high flow water pump. 180 would be as high as I would go, and personally I like Robert Shaw thermostats. They flow better then stock. you can see the difference in flow restriction in the store.
Next Oil Change I would suggest Changing to a Napa Gold filter. I was a skeptic a few years ago but when I changed from Fram to NG I saw a major oil pressure difference. you can search the forum for Fram vs Napa gold and find some interesting story's. just my opinion's Good luck.
06-27-2010, 02:45 PM | #18 |
yes, i do
yeah a good wix filter will help. i run nothing less than 10w30 in my trucks. i get a little concerned when my oil pressure gets to 15psi or less at idle that's when i start getting concerned. on any carb'd v8 i always run a 180* t-stat and i love stant t-stats. in all the time that i have been using them i have yet to have a stant fail on me or act funny.
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
06-27-2010, 03:06 PM | #19 |
Cruzin
i don't see any reason to worry, my car we build several years ago runs about 10 or so at idle and 30 down the road, dad always said a sbc can run with as little as 5-10lb pressure at idle (he made a living off working on this junk for 30+ years so i trust his judgement) like said above if you ain't hearing any noise you got oil pressure so i wouldn't let it bother me enjoy the drive
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
