06-26-2010, 08:15 PM | #1 |
Pics of fiberglass half door project
I have a set of hollow fiberglass doors for a C-10 that I am installing on my '72 Blazer 4x4. I wanted to make half-doors similar to what you see on Scouts and $roncos. I did a lot of research and found a two part polyurethane expanding foam that is hard enough to take any abuse.
I left the top strip attached for structural support as I added the pour foam. Man that foam and fiberglass resin is smelly stuff. I am installing the factory hinges and door latch hardware so I can open the doors if I want to. I will most likely paint them satin black after glassing in the top areas. I'll post more pics as I go on. The green C-10 is Mommas. It was her 20th anniversay present that she asked for. Thanks...Rick Last edited by Rick212; 06-26-2010 at 08:54 PM. Reason: more info |
06-26-2010, 09:21 PM | #2 |
Re: Pics of fiberglass half door project
want to see them installed.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
06-27-2010, 09:50 AM | #3 |
I'm gonna bolt one on this afternoon for a mock-up. I want to see if I need to cut the bottom area shorter or leave them the way they are.
Rick |
06-27-2010, 05:41 PM | #4 |
Nice idea, I'm subscribed....need another wifey, I'll hang around ya for 20 years, IF you buy me a C-10
That thing is clean, what's the 4X look like
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 06-27-2010 at 05:43 PM. |
07-03-2010, 05:40 PM | #5 |
Any progress?
