Old 06-27-2010, 12:24 PM   #1
sixbangr
sixbangr's Avatar
steering gear seal picture
anyone know where to get this seal? It is the small one inside the big nut.
1961 Apache short step.
sixbangr is offline   Reply With Quote
Old 06-27-2010, 12:36 PM   #2
mstrav1973
mstrav1973's Avatar
Re: steering gear seal picture
saginaw box right? I got mine from carquest, but I bet NAPA has it also. I just used a pick to pull the seal. You should also do the output shaft seal as well and that should cover you.
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!!
mstrav1973 is offline   Reply With Quote
Old 06-27-2010, 01:49 PM   #3
sixbangr
sixbangr's Avatar
thank you. Did you have to pull the box?
Old 06-27-2010, 02:52 PM   #4
mstrav1973
mstrav1973's Avatar
You can do it in the frame or out. I pulled mine because I painted it at that time. I would say other then a few extra bolts to fully remove from frame, it was nice using the bench instead of working around the frame and sitting on the ground.
Matt
