![]() Join Date: Dec 2008
autometer,air ride tech,weld,arp,etc..
new in box part#4486 autometer ultralight 3&3/8 programmable speedo.190.00
new in box part# 6604 ultralight tach matchs speedo w/ remote recall knob.190.00 info. http://www.autometer.com/cat_gaugede...id=3117&sid=11 http://www.autometer.com/cat_gaugede...id=3318&sid=11 http://www.autometer.com/cat_gaugede...id=3153&sid=11 the info. says the tach is 3&3/4 but its the same size as the speedo visually. just the mounting hole is slightly larger, or you can pedastal mount it as intended. new in box part#4402 ultralight blower press. guage 50.00 2 &1/16 guages in pic are already sold air ride technologies musclebar new but no box this fits 63 to 87 trucks 300.00SOLD http://www.ridetech.com/shop/suspens...musclebar.html ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() forgot to add this-new Universal 4link w/ chromoly tubing grade 8 bolts lock nuts,tube inserts & all rod ends etc.. 200.00 ![]() weld racing drag lights 15x8,15x12/5x5 the offset on the rears fit w/ the stock axle with no inner bed side work but you have to widen the wheel tubs if you run 31x15.50's. this is a nice way to get alot of meat on the road w/ minimal cost. 400.00 new air ride technologies ride pro e controller. this setup uses air press to monitor bag height.Its a 4 corner leveling system w/ optional remotes.The part#arc4700e,rem6500 comes w/ everything elec. no solenoid block,compressor,tank etc..400.00 SOLD new suicide doors lower 4 bar mounts . these are the axle end mounts for the lower bar & shock.http://www.*****************/4-link-k...er-lift-system might work for someone doing a custom 4link. link joint spread-2.5",3" axle tube,9/16 bolt hole,1/4" thk. these are sprayed w/ "dp sealer" 30.00 rebuilt & powder coated black hood hinges. one pivot has a bolt instead of a rivet but their pretty nice 100.00 new in package arp stainless 6 point 3/8 x .750 header bolts part#400-1102 15.00 SOLD fairly new one piece driveshaft.short bed big block,400 turbo short shaft .length from joint center 56.5", 1310 joints. the slip yoke has had a little material taken off the end. will take pics if necc.100.00 new 16" spal fanelec. .http://www.jegs.com/webapp/wcs/store...-1&showValue=3 can take actual pics if necc.75.00 front crossmember & control arms w/ air bags. Has been sand blasted & painted base coat,clear coat ppg fine silver.All shafts rebuilt.Will post pics mon. NO SHIPPING 150.00 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by mac72; 06-29-2010 at 09:16 PM. |
Re: autometer,air ride tech,weld,arp,etc..
wow, this is some nce stuff. This should sell Quick, TTT
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!! |
how much for just the front airbags?
wanna be 67
I am interested in the new air ride technologies ride pro e controller and header bolts...."I will take it"
ralphie628 let me chk. mon. & see if I have another pair.I would rather not sell these as the crossmember is setup for them.I'll let you know mon.
Mac 19stepside72 thanks & i'll get you a shipping quote tommorow I need your zip Mac |
Whole Autometer gauge set minus the blower gauge???
the gauges I have left are the speedo,tach & blower gauge.
![]() Join Date: Nov 2005
Does the Pro E controller use the height sensors or pressure sensors?
![]() Join Date: Nov 2003
$300 shipped for the muscleabar? 60640 is my zip code
Thanks, JE
Project Burro Viejo: http://67-72chevytrucks.com/vboard/s....php?p=3778216 |
EDIT: Sorry saw something after I posted.
---| 1967 GMC Stepside |-- 250 L6 .030 over ---| 1985 Porsche 944/1 |--- Build Thread: '67 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=378640 Last edited by LandonL; 06-28-2010 at 11:30 AM. |
#13 |
I'll take the sway bar.
#14 |
![]() Join Date: Feb 2005
Whats the best you can do on tach shipped to atco,n.j.08004 and it is a 3&3/4" tach pedestal mt. Right? Not a 5" dash mt.
#15 |
How wide is the sway bar? I am jumping in line, if it falls through.
#16 |
#17 |
#18 |
67cheby
![]() Join Date: Sep 2008
is the fan a pusher or puller and what size , how much Thanks
#19 |
Chevy Lover Till The End.
How much would it be to ship the WELD wheels to 37806?
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
#20 |
#21 |
#22 |
![]() Join Date: Oct 2008
Will you ship to Canada if so how much for the hinges shipped to T5W2A5 Thanks
#23 |
#24 |
67cheby
i have 2 16 inch pushers and i need pullers, i still havent sold mine
#25 |
wanna be 67
I received my air ride technologies ride pro e controller and header bolts.....all perfect items, well packaged and very fast shipping. Thank you Mac for everything.
