Old 06-27-2010, 02:12 PM   #1
swierker
swierker's Avatar
How do you guys run your exhaust?
I'm planning out my suspension upgrades including a drop and I'm thinking I may have to redo the exhaust. It is loops over the trailing arm right where it attaches to the frame crossmember.
So how do you guys run yours?
Stock setup?
Dump in front of the wheels? Behind the wheels?
Duals out the back? etc, etc.
Just looking for ideas... pics would be cool also.
Dan
swierker is offline   Reply With Quote
Old 06-27-2010, 02:57 PM   #2
Hubscrub
Cruzin
Hubscrub's Avatar
Talking Re: How do you guys run your exhaust?
here is mine it 90s out behind the wheel no tips,(got tips on all my other junk so i thought i would try something different)
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 06-28-2010, 01:54 PM   #3
white71chevy
white71chevy's Avatar
Mine dumps in front of the rear wheels right now but I'm getting a new true dual that comes out the back.
white71chevy is offline   Reply With Quote
Old 06-28-2010, 02:07 PM   #4
07SSSC
07SSSC's Avatar
A friend and I (ok mainly him) tried 3 different times to get my exhaust straight out the back, never worked. I had to cut it off after I did a 2/4 drop and we tried reattaching it with new bends but still couldn't get it to work. Maybe with new pipe we could make something work, but for now it's dumping out in front of the wheels. We even had the bed off twice trying to make it fit and not rub. Keep in mind I have 3" pipe and a fuel cell back there too which doesn't help matters but the problems were with the axle.
'69 Chevy C/10-under reconstruction -- '68 C20 Camper 50th Anniversary-runs, but sorely needs a resto --
'07 Cobalt SS/SC-very fun DD -- '93 Chevy K2500-LQ4/4L80E swap --
'84 Trans Am-awaiting (LS) drivetrain -- '00 Trans Am-road tripper -- '06 Z06-577 WHP beast
07SSSC is offline   Reply With Quote
Old 06-28-2010, 02:13 PM   #5
michael bustamante
michael bustamante's Avatar
mine was set up exactly like hubscrubs pics but now that I bagged it , I have the outlets under the truck dumping just before the rear end
1967custom
michael bustamante is offline   Reply With Quote
Old 06-28-2010, 03:42 PM   #6
Fitz
When I did mine I ran the entire system between the frame rails...front to back. That way the lowest part of my truck is the trans oil pan.
Fitz is offline   Reply With Quote
Old 06-28-2010, 04:01 PM   #7
SATownChevy
SATownChevy's Avatar
^ looks like someone spent a little green to get the electric dump.
i got the cable version
View pics of my truck - 1968 Chevy C10 SWB - Photobucket
I'm not wasting money on my truck, I'm helping to rescue the economy one mod at a time.
SATownChevy is offline   Reply With Quote
Old 06-28-2010, 05:50 PM   #8
'72customdeluxe
headers, 90'd to outside of frame rail, mufflers under cab, 45* sweep out from under the steps.
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 06-28-2010, 06:27 PM   #9
67lngbed
67lngbed's Avatar
Hey Fitz where did you get those headers, And how much were they. My longtubes dump out on an angle below the frame. They look like they dump into the frame.
Thanks.
Karl
67 c-10 lwb
81 trans-am (in 1000 pieces)
92 firebird (pos)
63 austin heally sprite (future project)
58 chevy pickup (future project)
67lngbed is offline   Reply With Quote
Old 06-28-2010, 06:32 PM   #10
Bad70sbchevy
Bad70sbchevy's Avatar
Runnin sidepipes on mine coming out before the rear tires
Bad70sbchevy is offline   Reply With Quote
Old 06-28-2010, 06:50 PM   #11
cam.man67
cam.man67's Avatar
Same here, but I've got a 90* sweep out a foot in front of the tire.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 06-28-2010, 07:17 PM   #12
swierker
swierker's Avatar
Here is the where exhaust hooks over the trailing arm. After the manifolds the two pipes join into one and it runs below the frame until here. These are looking at it from the drivers side. I think with a 5-6" rear drop the trailing arm will hit the exhaust. Looks kind of strange to me.
I'd rather not have to redo the exhaust when I do the drop but I may not have a choice. Do you think this will be a problem with the drop? Do the trailing arms have that much travel or will I just have to find out when I do the drop?
Old 06-28-2010, 09:39 PM   #13
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Now this is on an inline, but here's how the exhaust is ran on my '69:
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-28-2010, 09:55 PM   #14
CUSHE63
CUSHE63's Avatar
CUSHE63 is offline   Reply With Quote
Old 06-28-2010, 10:34 PM   #15
'72customdeluxe
^having a small diameter h-pipe installed to eliminate the helicoptering effect with the windows up. Mufflers are 4x14 magnapak bullets. Pretty mellow cruising then wide open when wide open.
