Old 06-27-2010, 03:34 PM   #1
crapy67
White wall terror
crapy67's Avatar
before and after pics
here are some before and after pics of my 71 I just did the suspension on
before, after
crapy67 is offline   Reply With Quote
Old 06-27-2010, 03:41 PM   #2
POPO1984
POPO1984's Avatar
Re: before and after pics
is it a 4/6 drop
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 06-27-2010, 03:48 PM   #3
crapy67
White wall terror
crapy67's Avatar
some more
Old 06-27-2010, 03:51 PM   #4
crapy67
White wall terror
crapy67's Avatar
No POPO Its a 3/5 from CPP
Old 06-27-2010, 04:11 PM   #5
mstrav1973
mstrav1973's Avatar
always nice to see a felow mechanical tradesaman on the boards. Any engine pics?
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!!
mstrav1973 is offline   Reply With Quote
Old 06-27-2010, 04:25 PM   #6
70cst
70cst's Avatar
Nice lookin drop crapy67
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-27-2010, 04:31 PM   #7
hchad18
hchad18's Avatar
Looks good
hchad18 is offline   Reply With Quote
Old 06-27-2010, 04:50 PM   #8
crapy67
White wall terror
crapy67's Avatar
Here's some pics of my bone stock 307 power house
Old 06-27-2010, 04:52 PM   #9
bad6772
Official Site Guitar Shredder
bad6772's Avatar
looks *****in i would not change a thing
bad6772 is offline   Reply With Quote
Old 06-27-2010, 04:53 PM   #10
crapy67
White wall terror
crapy67's Avatar
The only problem I have with the drop is that it's an Inch lower in the rear to the front Anyone else out there have this problem ?
Old 06-27-2010, 05:22 PM   #11
KMACD71
KMACD71's Avatar
The back does look lower than 5 compared to the 4 mine is dropped. Looks more like 2 inches lower than mine.
KMACD71 is offline   Reply With Quote
Old 06-27-2010, 05:58 PM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Much better IMO...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-27-2010, 06:25 PM   #13
crapy67
White wall terror
crapy67's Avatar
The bump stops are hitting the axle, I had to cut an inch off them to get them off the axle.
Old 06-27-2010, 10:37 PM   #14
knsmodels
I make Models
knsmodels's Avatar
looks good......I am right around the corner from ya.....I will look for ya on the road...
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 06-27-2010, 11:43 PM   #15
crapy67
White wall terror
crapy67's Avatar
Where at in Bucks are you?
Old 06-28-2010, 08:04 AM   #16
68Stepbed
68Stepbed's Avatar
Looks pretty good. I do beleive they may have sent you the wrong rear springs. My 5" rear drop doesn't sit that low and I have lots of room between the axle and stock bumpstops.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 06-28-2010, 08:11 AM   #17
big_al_71
big_al_71's Avatar
huge improvement!!! new stance..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 06-28-2010, 09:19 AM   #18
Racie
The front will probably settle some more after a few good miles...
Racie is offline   Reply With Quote
Old 06-28-2010, 09:45 AM   #19
POPO1984
POPO1984's Avatar
Looks good. I have the same from CPP on my truck. Well on my frame since everything is in pieces. Im gonna be lower than i thought
South Houston
Old 06-28-2010, 10:46 AM   #20
epashhans
epashhans's Avatar
I just put the 3/5 from cpp in my 67 (its a short wheel base) and I think my front is a bit higher than my rear, but just barely if it is. I have a big block up front though, so that might be squatting the springs a bit more than your sb. I am not on my rear bump stops though. I don't think cpp has a 6" drop spring available do they? Maybe that is what you got though.
'67 C-10 Shorty - 454, 5spd, and speed holes!
epashhans is offline   Reply With Quote
Old 06-28-2010, 11:11 AM   #21
crapy67
White wall terror
crapy67's Avatar
All my receipts say its a 5 inch drop kit. My rear measures from the ground to the top of the wheel well arch is 28 3/4 the front is 29 3/4
Old 06-28-2010, 01:52 PM   #22
crapy67
White wall terror
crapy67's Avatar
I'm sending the rear 5 inch springs back and Jeff from CPP is sending me a set of 4 inchers
Old 06-28-2010, 11:16 PM   #23
knsmodels
I make Models
knsmodels's Avatar
sent you a pm....
