Old 06-27-2010, 06:41 PM   #1
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Installing Divorced 205, but I need your input
Ok, I'm going to go out on a limb here and consider my 486 build complete. So here is what's next. I've had a D205 since the before my motor build and now its time to start working on it. I have a few ideas on how to mount it, but I want to see if any of you have a better idea. I know for sure that I am going with NorthWest Fab 205 cable shifter.
The TCase is a Dana 300, but that is the same shifter for the 205
Here are some of the ideas I have found:
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 06-27-2010, 06:58 PM   #2
msgross
msgross's Avatar
Re: Installing Divorced 205, but I need your input
all of those ideas look pretty sturdy...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-27-2010, 08:17 PM   #3
SanitysBane
Those do look sturdy but personally I would want something on the bottom of the transfer case so stuff will hit it and no the case.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 06-27-2010, 09:36 PM   #4
Davetopay
I am liking the way the last example rotates the case a bit counter clockwise and helps keep the front output from hanging real low. Being a divorced case it will be mounted further back so as to make the front driveline angle a bit less extreme. You could easily add a lower guard to keep it from getting bashed.
Davetopay is offline   Reply With Quote
Old 06-27-2010, 11:14 PM   #5
Chevy1TonFun
Grease Monkey
My truck has a 18" lift kit. The frame rail is 40" from the ground, I don't think anything could hit the T-Case, lol. Unless someone t-bones me(knocks on wood).
I'm thinking the first design, I am thinking more of a horizontal position for the tcase.
Old 06-28-2010, 12:05 PM   #6
tomtuna1978
im thinking that the last one would be easiest to r@r (looks like it would drop rite out), and its got the shifter bracket on it ! i like that !!! but like sanitysbane said id like somthing on the bottom of it. not for a shield but for support. the 4 bolts on top dont look like enuff support for that heavy beast ! id build a cage arround it like that last example. just my opinion
tomtuna1978 is offline   Reply With Quote
Old 06-28-2010, 08:25 PM   #7
b454rat
I have a pic somewhere of my crossmember. I'm using a Ford 205....
And the bolts that hold it up are what the factory uses, they are some pretty decent sized studs, if it works from the factory it will work for me.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 07-10-2010, 01:13 AM   #8
woodwright
Enjoying left field
woodwright's Avatar
I think these type mounts would be stronger than hanging off of an aluminum th350 or th400. And as far as something hitting it, These things are stout. They could probably take a hit from a 30lb sledge.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 07-10-2010, 01:30 AM   #9
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Northwest fab has a bad rep!
http://coloradok5.com/forums/showthr...t=nwf&page=105
start post 1046
http://coloradok5.com/forums/showthr...&highlight=nwf
nothing but nwf. Good luck if you do waste your money there.
I will also be installing a divorced 205 on my 83 i believe when i convert it to a 4x4.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
