Old 06-27-2010, 06:44 PM   #1
C10Slim
Lowered truck headers
I have searched and have been reading posts all day and probably more confused then when I started.
I am looking for a set of headers for a lowered 64-66 (5/7 drop), Auto trans column shift, and a SB383. I may also bag it later so want something that doesn't hang to low. Leaning towards a set of Patriot Clippster Headers.
Does anyone have a simular setup? What are you running?
C10Slim is offline   Reply With Quote
Old 06-28-2010, 01:48 PM   #2
Oklahoma
Re: Lowered truck headers
I'm running ram horns right now, was thinking of going to block huggers, they should work for you.
Oklahoma is offline   Reply With Quote
Old 07-02-2010, 07:51 PM   #3
chillware
I'm curious on this too.. subscribing to thread.. thanks!
My build thread: '66 Chevy
chillware is offline   Reply With Quote
Old 07-02-2010, 10:24 PM   #4
Rich 5150 69
Rich 5150 69's Avatar
I`ve seen several of our trucks with the patriots clipster and 3/4 lenght hedders made by flowtech, sanderson also sells several differant hedders that will fit http://www.sandersonheaders.com/1960...Truck-Headers/
Flowtech http://www.holley.com/31500FLT.asp
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 07-02-2010, 10:37 PM   #5
protrash64
Resistance is Futile
protrash64's Avatar
I used Summit 9014(?).....for a 88-98 SB truck. They are shorty's. Had to weld up the O2 sensor hole and they were a little tite, but my engine is in the front position. Others that will work are shorty's for the 80's-90's square bodied Camaros.
My entire exhaust is above the frame with it routed above the trans x-member.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 07-03-2010, 12:11 AM   #6
shortbed70
shortbed70's Avatar
my engine is moved forward about 2 inches and i run lt's off a 74 camaro with very good ground clearance.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 07-03-2010, 10:03 AM   #7
sixtyfour
Zombie Killer
sixtyfour's Avatar
Do you have any pictures of your exhaust system?
1964 C10 Long Step
sixtyfour is offline   Reply With Quote
Old 07-03-2010, 10:06 AM   #8
protrash64
protrash64's Avatar
Here are some old one's of the headers.......my truck is too low to get under.......
Old 07-03-2010, 10:13 AM   #9
shortbed70
shortbed70's Avatar
I plan on running mine through the frame also with long tubes heres a pic how they look under truck
Troy
Big Red Dog build
Old 07-03-2010, 03:26 PM   #10
C10Slim
Yeah those look perfect! Do you know what brand and model those are?
Old 07-13-2010, 10:03 PM   #11
C10Slim
Well the clipsters didn't fit! #1 tube hit the motor perch. Any other recommendations?
Old 07-13-2010, 10:38 PM   #12
C10Slim
Ah ha! I think I found the ones shortbed70 has:
http://www.jegs.com/i/Flowtech/387/11108/10002/-1
The extra circle tabs on the flange clued me in. I think I might give these a try.
Old 07-14-2010, 12:08 PM   #13
vin63
It's Better With Nitro
vin63's Avatar
I found that the Hedman shorty swept back style worked well for a lowered application, and provided flexibility with routing configurations to keep the tubing above the bottom of the frame rails. Here's a link to a BBC exhaust thread here that I posted photos of my system.
http://67-72chevytrucks.com/vboard/s...94#post3894894
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-14-2010, 01:10 PM   #14
Hickup pickup
Hickup pickup's Avatar
If you are planning on bagging your truck I would recomend a good pair of short headers so you can run the exhaust outside your frame , otherwise you will be very limited for space. JOMO
2-20, 2-21 whatever it takes!
Hickup pickup is offline   Reply With Quote
Old 07-14-2010, 01:16 PM   #15
C10Slim
Yeah the problem is finding shortys that will work with the CPP perches. Alan's Classic is having the same issue. CPP gave him some part numbers so I am going to try the Headman 69646's and see if they will work.
Fingers crossed!
Old 07-14-2010, 07:31 PM   #16
shortbed70
shortbed70's Avatar
Well my truck is bagged and no problems with exhaust. Headers are from summit SUM-G9001.
Troy
Big Red Dog build
Old 07-26-2010, 08:54 PM   #17
C10Slim
Finally found the perfect header!! After trying 2 different sets I was about to order my 3rd to try when my latest issue of Custom Classic Trucks arrived... To my surprise they were doing a tech article, putting an exhaust in the "Get Shorty" project. They used a set of Doug's Tri-Y headers and claimed they fit great. I said what they hell I might as well give them a try...
These headers fit almost perfect! Just a little trimming on the pass side rail and they dropped right in. Even better they are true longtubes and don’t hang below the rails but a fraction of an inch. They are a bit pricey at $605 but well worth it for their fit, coating and longtube design. They are Dougs D375Y.
Man what a relief to finally have these in and move on to the next part of the build!
Old 08-01-2010, 02:46 PM   #18
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Fingers crossed!
Did you even try the Hedmans? Just curious. Thanks
Alan's Classic is offline   Reply With Quote
Old 08-27-2010, 08:59 AM   #19
likaroc13
Rollin' Old Skool
any updates? i have to think into the future for mine, since it's not lowered yet...my dilemma is whether to run exhaust inside or outside the frame...i will most likely use shorty headers....i want the exhaust to exit at an angle just in front of the rear tires...but if you run outside the frame, there's no way for a crossover pipe (H or X)...i could do a crossover if the exhaust is inside the frame rails, but i know it would be a tight fit...any recommendations on whether a crossover is needed? my '66 has a mostly stock 327 w/ 2spd Powerglide
