Old 06-27-2010, 07:51 PM   #1
COBALT
COBALT's Avatar
Possible steering box problem
Over a year ago the '99 tahoe we inherited starting having steering problems. I had already looked it over pretty good when I first got it, but the noise in the steering one day got my attention. It turns out the ps pump was leaking badly, and the hoses appear to be worn out. It looked like a slow leak suddenly turning into a bad one. I checked the reservoir and sure enough it was pretty much empty. I filled it back up again just to see how long it would take to empty out - not long at all. That's really bad.
I replaced the pump and the lines without too much difficulty, and the steering felt 110 % better, but I noticed some play in the wheels now when I have them up on stands with the steering locked.
Both wheels can be moved a bit by pushing on one side of the tire while pulling on the other. This doesn't seem to be isolated at one wheel, and I was having a hard time identifying exactly what was wrong - the tie rods seem to be in pretty good shape. I managed to get down on my side and push the back of the wheel with my foot while pulling on the front, and watch the idler arm and steering linkage when I did this. The play is at the pitman arm. It looks as though the steering box is letting the wheels turn a bit.
Ok, so I'm thinking the steering box was probably damaged by that leak way back when. Thoughts?
Another issue that I found. If I push on the top of the wheel and pull on the bottom (and vice versa) there's a tiny bit of play as well, but it's more distinct - there's a bit of a clunk, and the exact same amount of movement on both sides. Pulling and pushing on the wheel in and out yields no movement, and I'm not hearing any wear when I spin the wheel at all, so I think the bearings are fine, but I'm worried about the upper/lower ball joints. I don't see any play in the A-arms when I do this either. I've seen bad ball joint wear on these 2wd suspensions, and this doesn't look familiar to me, but things aren't tight and that has me wondering.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 07-08-2010, 08:17 PM   #2
jamie72
jamie72's Avatar
Re: Possible steering box problem
sounds to me like ball joints,and other wore parts on the frint end, i really don`t think the gearbox would be hurt because of the leak.
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 08-07-2010, 02:06 PM   #3
COBALT
COBALT's Avatar
You might be right - the only thing that bothers me is the amount of play in the steering output shaft when the steering wheel is locked, but there's also enough play in the wheels to make me think both sets of upper and lower ball joints might stand a replacement. Not sure about the tie rods. They seem to be ok, but I might as well replace them if I'm going to go through the trouble of replacing the ball joints...
Decisions decisions. I don't want to leave out the steering box if I'm going to have the front-end apart anyway.
Seattle, WA.
Old 08-10-2010, 11:58 AM   #4
fxdxharley
Just a nother gear head
fxdxharley's Avatar
the boxes are adjustable. there is a scrrew with a lock nut on the top of the steering box that is used to adjust the gears. my trk has the same play like yours. try adjusting the screw to tighten up the slop. If you have a a repair manual it tells you how to do it.
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
