Old 06-27-2010, 11:49 PM   #1
dmartin1
dmartin1's Avatar
5.3 vortec in an older truck?hows it done?
ok so i have access to a chevy 5.3 2003 vortec with 50k miles on it cheap.
how do you do the swap?
ok im not THAT stupid ive swapped several engines,but how is the new vortec put into the old truck?
motor mounts?will it bolt up to my turbo 350?torque converter?
all the specs on this conversion would be awesome!
thanks in advance,id love to have the 5.3 vortec in my old 4x4 haha
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 06-27-2010, 11:56 PM   #2
85burb
85burb's Avatar
Re: 5.3 vortec in an older truck?hows it done?
There is about 15 of these going on right now. Just have to search it. Are you going EFI or carbed? List is about same both ways. I am putting a LQ4 6.0 with a carb in my 4x4 burb. I needed:Fuel system, intake manifold, motor mount adapters, new flex plate/flywheel, the factory manifolds do not fit all that well. You will also need ecm reprogram if you keep efi or a msd controll box for carb. Lots of different ways to get them in. Many different combos you can use.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 06-28-2010, 04:02 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
http://www.hotrodlane.cc/77chevytruck/77chevy.htm
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 06-28-2010, 08:44 AM   #4
78-5.3
78-5.3's Avatar
check out my truck been on the road about a year there are other videos to the start of the engine on you tube too
i would run the injection setup on the truck mine gets about 20 mpg you would want to run a 4l60e trans too so you dont have to deal with the vss or kick down setup for the t350 biggest issue is the headers !! other than that its the fuel pump , engine mount adaptors , harness etc etc its pretty easy
78 C-10 5.3 LSX -4L60E
78-5.3 is offline   Reply With Quote
Old 06-28-2010, 09:39 AM   #5
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Search LS swap, there about 10 currently under construction with LOTS of good pictures and instructions. Good luck.
--Josh
