06-28-2010, 10:19 AM | #1 |
DiablosWeldingFabrication
Heater Delete Panel
Im made a heater delete panel and want to see what you guys have made or added on to fill the hole. I was thinking of putting some switches and maybe a air gauge.
06-28-2010, 10:28 AM | #2 |
Re: Heater Delete Panel
I don't have one, but I did see this factory looking one in a C60:
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
06-28-2010, 10:52 AM | #3 |
^^^ That's all my 64 has.
06-28-2010, 11:44 AM | #4 |
meowMEOWmeowMEOW
i just have the single knob as well.
06-28-2010, 11:49 AM | #5 |
huh!.....mine had all the heather knobs!
06-28-2010, 12:25 PM | #6 |
I removed my heater controls and left it open planning on welding a plate in. Drove it for a couple of years like that, then My friend picked up a rusted out parts truck and it just happend to have a perfect heater delet plate that is only a slight shade diffrent from my dash. changes the whole look of the dash with it in.
06-28-2010, 12:35 PM | #7 |
Senior Enthusiast
My dash is the earlier configuration, but I had my son machine some aluminum plates to look similar to the originals shown in the first picture. Then I could mount whatever I wanted on them.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
06-28-2010, 12:56 PM | #8 |
I'm curious, what did you use for the textured appearance? I did some test panels w/the VHT wrinkle finish rattlr can stuff & it looks very similar.
06-28-2010, 01:08 PM | #9 |
This is the stuff i used! it comes in different colors but you can paint right over it! i did the whole inside of the cab and were the stereo goes...oh and the inside of the glove box door
06-28-2010, 01:18 PM | #10 |
06-28-2010, 03:04 PM | #11 | |
Senior Enthusiast
After disappointment with some inconsistency problems years ago, I always use heat lamps when applying this paint, no matter what time of year. I have 2 heat lamps mounted about 3 feet apart, about 20" above the work surface, with the beams converging in the center. I preheat the metal for about 20 minutes until it is really warm, then flow on the paint. After spraying I let the lamps cure the paint completely for several more hours. Then it's just a matter of how much paint gets applied depending on how shallow or deep I want the wrinkled finish.
06-28-2010, 03:07 PM | #12 |
Senior Enthusiast
That looks really cool, I like the color. I just realized the textured paint you used is the same stuff (different color) I used to create the street surface in my Universal set diorama. It's really versatile.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 Last edited by markeb01; 06-28-2010 at 03:22 PM. |
06-29-2010, 12:47 AM | #13 |
Ya! it holds up really good and its child proof!!!! it does not scratch easy...i shot some satin black over it to give it more of a cutom look! some people think its the roll on bed liner!
