Active Member
![]() Join Date: Oct 2006
Solenoid valve mounting
Was wondering where you guys are mounting your solenoid valves? Building brackets etc? Also do the 2 front ones need to be close to the front of the truck to work properly? Any pictures would be helpful.
Re: Solenoid valve mounting
You can buy brackets or build your own pretty easily. The valves don't have to be close to the bag they are working. As for location find a place that is easily accessible and provides protection from road debris.
![]() Join Date: Sep 2007
I mounted mine to a piece of flat stock with short u bolts and bolted them to the side of the frame right underneath the front part of the bed.
1967custom |
I had some L-shaped brackets layin around that I drilled some holes in and mounted to the frame under the bed up near the cab. Then bolted the valves on to them. They work fine.
low n' slo
![]() Join Date: Mar 2009
i used small u bolts from lowes and bolted them to flat piece of metal, then bolted that in between my frame rails behind my gas tank. i will build a hatch that opens on the floor so i can service them if i need to. heres a pic..
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
Active Member
Thanks guys I was going to fab a bracket to put them all on but just wanted to see what other people where doing.
Happy to be here
![]() Join Date: Mar 2000
As mentioned find a safe location and build your bracket to fit. There have been a couple threads on the subject with some good quality pics. Try drilling down through the posts and see what you find.
