Want to know if I can get a 5 sp out of a 93 and swap into my 69 GMC swb it has an 84 350 with stock 3sp on tree. Will it bolt up to my moter and is the pioLt bushing the same size? Etc. Any help is a big help.
Re: 3sp to 5sp trany swap help
What model 5 speed are you considering using?
I've done 2 conversions useing the T-5 from an S-10 but i've never changed over to a 3500 or 4500. |
Iam not even sure yet. Guess I shoulda asked that to. it just an idea I had. Will the T5 hold up to the 350? And where did the shifter come out in frount of the seat. I have a 5 sd out of 84 camaro but the shifter is to far to the rear. I don't want bucket seats.
If the 93 is a 1/2 ton, the transmission is most likely a NV3500. It will bolt to your block and the pilot and clutch spline are the same as your 3 speed. The bad news: It will require hydraulic clutch linkage and it has an electric speedo drive. All of this is fixable, but it is not a bolt-in swap.
A T-5 is a much easier swap because you can keep your stock bellhousing, but it is not a very strong transmission. If you do decide on a T-5 it should be from a 92 or earlier S-10. The bolt pattern changed in 93 and the later transmissions will not bolt to your bellhousing. I have been running a T-5 behind a 305 for several years now and I have had no problems, but I drive it like I own it. The shifters on both the NV3500 and the S-10 T-5 will clear your bench seat. Ray |
