Old 06-28-2010, 05:38 PM   #1
70chevymanshort
Question Radiator support brackets
I have a 1970 chevy frame and I am putting a 1968 front clip on it, will this work? The reason I'm asking is because the width of the frames are different.
70chevymanshort is offline   Reply With Quote
Old 06-28-2010, 05:57 PM   #2
gkesseru
gkesseru's Avatar
Re: Radiator support brackets
It will work. From everything I've learned on this forum, the front frame widths are the same from 67 through 87. From the title of your thread it seems like you intend to use the 70 radiator support panel with a 68 grill. If so, see this thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=399960
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 06-28-2010, 06:12 PM   #3
70chevymanshort
The frame rails in the front measure different. I am using a 68 radiator support, fenders, hood, ect. On a 70 frame.
Old 06-28-2010, 06:54 PM   #4
Shyguy
Junior Member
Shyguy's Avatar
We put a '67 body on a '69 frame, it fit ok. I am still working with a few minor alignment problems with the body.
The problem I had was because I did not know that the back cab rubber mounts are thicker on a three quarter ton. We put a body off of a three quarter ton on a half ton frame using the thicker rear cab rubber mounts from the three quarter ton frame.
Just another mistake I have to correct when I start the restoration on the truck.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 06-28-2010, 08:57 PM   #5
gkesseru
gkesseru's Avatar
The later frames have a larger hole for the radiator support mounts and the rubber mounts are thicker.
72 Fleet (died)
78 Step (sold)
00 F150
Old 06-28-2010, 11:59 PM   #6
70chevymanshort
Thanks guys for your info. Does anyone know the width demensions of the frame rails on a 70 or 67 chevy truck? I just want to know if mine are bent or not, thanks
Old 06-29-2010, 01:11 AM   #7
70chevymanshort
I have a 71 frame for sale and 70 parts for sale also.
