Old 06-28-2010, 08:50 PM   #1
GMC1968harrington
My 1968 GMC 1500 327ci 2wd
I got this truck from my father in law it was purchased by his dad in 72 and his brther had it since 84. It seems like solid truck other than the typical rust in the lower cab. My plan is to make a rod out of it. It has power steering that is disconnected and a tired front suspension. It has leaf sprung rear end so i assume it is more exspensive to lower than coils. He also has a 72 CST that is for sale but i can take what parts i want but not to sure what i should other than the factory tach. It is a 3/4 ton so if anybody has any ideas of what would be a good part to take and use in my 68 let me know. I will keep updates as i slowly rebuild this truck.
GMC1968harrington is offline   Reply With Quote
Old 06-28-2010, 08:54 PM   #2
70cst
70cst's Avatar
Re: My 1968 GMC 1500 327ci 2wd
& from Roseville Ohio. Looks like you have a very nice lookin GMC plus it comes through the family which makes it a little more special. As far as you questions...stay tune and the answers will soon come.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-28-2010, 10:20 PM   #3
btullis99
btullis99's Avatar
you can lower the rear 2 inches easily with drop shackles. cpp sells em. might check with some of the vendors here, like mike's bump and grind.
btullis99 is offline   Reply With Quote
Old 06-29-2010, 08:36 AM   #4
68Stepbed
68Stepbed's Avatar
Since the front suspension is "tired", I would go ahead and upgrade to disc brakes while rebuilding everything.
Is the 72 CST a Chevy or GMC? If it's a Chevy, it may have a coil spring rear, which you could change out, which would make it easier and cheaper to lower.
That's a nice looking starter truck for sure. What is the canister next to the master cylinder? Is that an external oil filter?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
