RUNNING OUT OF TIME
![]() Join Date: Jan 2010
Has any one ever used a 1978 or similiar frame and suspension for a 1958 chevy shorwide. I bought a running 1978 chevy short wheelbase step side truck, and wanted to mount my 1958 on these suspension.
1958 CHEVY SWBFLEETSIDE 1971 CHEVY SWB 1968 CHEVY SWB 1962 INTERNATINAL 1978 CHEVY SWB STEPSIDE -SOLD- 2003 CHEVY Z-71 2010 ESCALADE (WIFE'S )
Re: 1978 chevy donar frame
too wide!
Not exactly what you are asking about......
http://www.thehollisterroadcompany.com/C10ifs.html |
My 59 has 74 front and rear axles. As you can see from the photo with skinny tires (7.50 x 16 in that photo) the outside is just even with the vertical front fender and rear bed sides. Any wider tires or "dished" rims and your tires are outside of the fenders, which means rocks, dirt, etc. will be kicked up on the side. In some states you need to run full flares if the tires stick out beyond the fender. If you do a search you will find some trucks on the C series frames.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Hollister Road Co.
here is one on an 82 chassis
http://www.thehollisterroadcompany.c...#39;s59004.jpg |
Hollister Road Co.
#7 | |
58 Apache short fleetside ona 64 chassis:
RUNNING OUT OF TIME
I also have a 70 chevy short wide parts truck. With leaf springs on rear. Would that be a better choice than the 78'.
#9 | |
![]() Join Date: Jul 2007
I'm with the guys who say they are too wide "if" you want to run wider or reverse rims and wider tires and lower the truck down where most guys who lower trucks like them.
That little red truck that Dwscr posted the link to is sitting at pretty close to stock height and is running fairly narrow tires with what look like Ralleys with no reverse to them. Sometimes what looks like the easiest and or cheapest way isn't necessarily easy nor cheap in the long run. If you have enough gumption and fabricating skills and equipment almost anything can be made to fit on another chassis but getting it on there and then having it "look right" is another whole can of worms to open and consume. |
#11 | |
Biggest problem is the front radiator mount but I have also worked through that with some other parts of another similar frame. However there is now a guy who sells prefab kits for about 700.00 or 800.00 bucks and then you just bolt/weld it all together. He has them for a couple of different frame body swap combinations but for sure one that bolts our cabs up to these frames. I will see if I can find his name if you want? Tire and wheel fitment is a bit of an issue but there is lots of choice out there. I am not dropping mine to the ground so it should not be a big problem. 56hotrodred |
| Bookmarks |
