06-29-2010, 03:52 AM | #1 |
good idea or bad.........
im building a rear bag set up for my burb, and the lower mounts will hang the bag bracket cup about half way off the side of the trailing arm. and i was wondering if it would be ok if i built a bar to go from one trailing arm to the other, (between bag mounts) with adjustable rod end bushing on both ends to help reduce the twisting motion of the arms, but still alow them to move independently. will doing this be ok or will it want to fight the panhard bar, or would it not even be needed?
thanks in advance for any advice on this question of mine. |
06-29-2010, 07:43 AM | #2 | |
67-72 parts collector,…
Re: good idea or bad.........
I think the bag bracket would be fine if gusseted properly. It is going to want to "twist" the arm. You might want to plate the top and bottom of the stock trailing arm.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 06-29-2010 at 07:44 AM. |
06-29-2010, 08:30 AM | #3 |
Squarebody guy
I think bushing wear and stress on the axle mounts might be a factor as well after t-arm plating. I don't think rod ends will help with twisting as much unless you use two, one high and one low, it seems like too much stress to me.
