Old 06-29-2010, 09:36 AM   #1
primetime
primetime's Avatar
so she's back sitting in the garage again.
now that i have my truck back on the road, i have found a new problem. my poor little monojet is leaking from the front and back. fuel just trickling out. its not coming from a line that can be tightened or anything. i had two other guys take a look at it for me ,that also own 73-87 chevy trucks, and both say its gonna need a rebuild or replace it. i'm not fluent in carbs so rebuilding doesn't seem to be an option for me. and it looks like a new monojet is around $250 dollars so that isn't looking good for me either. spending that much i might as well convert to a fuel injection setup. so my question is: if i upgrade to fuel injection how much do i gain in mileage/hp as compared to buying a new 'old' monojet? cost for cost
1968 Chevy C10 swb fleetside
2005 Chevy Silverado crew cab (SS)
1977 Goldwing cafe racer
1977 Chevy nova (first car/ first love)
primetime is offline   Reply With Quote
Old 06-30-2010, 09:03 PM   #2
primetime
primetime's Avatar
Re: so she's back sitting in the garage again.
i hear crickets chirping
Old 06-30-2010, 09:17 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
I am by no means mechanically inclined. I've never torn in to an engine, never done much besides swap a radiator or condenser and put a starter on. But, back in the late 80's I did rebuild a quadrajunk, and it was not all that hard. All in all though, to be honest, even after rebuilding it I ended up with a new edelbrock.
Can you really get close to a fuel injection setup for $250? I know to go to a TBI you're looking at wiring and computer, plus the in tank fuel pump setup. Of course that is a factory TBI setup, not familiar with aftermarket FI setups.
RandyP is offline   Reply With Quote
Old 06-30-2010, 11:14 PM   #4
87 chevy silverado
me personalty i would get a new carb for it o try to have that one rebuilt. but if u go to tbi u basically better of getting a donor truck if u go that rout. hope this helps
87 chevy silverado is offline   Reply With Quote
Old 07-01-2010, 12:18 AM   #5
BigRed76
BigRed76's Avatar
carb rebuild kits are cheap, and a monojet is very easy to do, not many parts. I would take on the task of rebuilding it before buying another or doing something as serious as an efi swap. Biggest thing is to have a book on the carb, or pictures of it.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 07-01-2010, 12:56 AM   #6
USSkoval
If the body of the carb is still in good shape, just rebuild it. You don't need to know anything about carbs, you just need to know how to pay attention to what you are doing. Pretty simple.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 07-01-2010, 01:09 AM   #7
BigRed76
BigRed76's Avatar
Zach
Old 07-01-2010, 02:38 PM   #8
primetime
primetime's Avatar
well, i guess i'll try it. i don't think i can make it leak any worse than it already is.
Old 07-01-2010, 09:07 PM   #9
BigRed76
BigRed76's Avatar
that is true. just make sure there arent any pieces leftover when your done
Zach
Old 07-02-2010, 12:05 PM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
sounds like the throttle plate wore out,replace it all,carb kits i've done don't have this part,would still leak,you might just flood engine if lucky.Or worse FIRE
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 07-02-2010, 12:10 PM   #11
Low87
been here longer than Liz
Low87's Avatar
That's usually how I gauge my successes and failures. Though projects with peices left over usually tend to turn out better in the long run.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 07-03-2010, 09:29 AM   #12
BigRed76
BigRed76's Avatar
How would a worn out throttle plate cause the carb to just start leaking from everywhere?
Zach
Old 07-06-2010, 09:12 AM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
i had gas drip out all around the post coming threw,pile up in the intake pockets.
I was in getting exhaust put on ,(muffler shop)guy see's that says gotta fix that,
it's the throttle plate wore out from spring/pedal tension.
I ordered carb from my parts guy,got it on in the parking lot,running atleast,
back in,pipes on,when set up ran great.
Before this ,the carb would bog/smell it/and i did carb kit .i had not seen it happen before,but someone else must have
John
Old 07-06-2010, 10:28 AM   #14
78 Chevyrado
I used to use that system until the stuff I buy started to COME with extra parts... now I have no clue if I did good or not...
78 Chevyrado is offline   Reply With Quote
Old 07-06-2010, 11:19 AM   #15
BigRed76
BigRed76's Avatar
Oh yeah that makes sense. I've seen that happen to alot of q-jets. I do believe there is a company that makes a kit to repair that problem.
Zach
