02-17-2003, 03:34 PM | #1 |
Better late than never
Motor mounts
I can't remember what bolt is used to attach the mount to the tower. Also, is it just a bolt & washer, or is there another rubber piece that I should be looking as well.
Sure wish I would've been more organized 10 yrs ago when I stripped the truck apart. Thanks for your help.
1970 C/10 SWB Stepside |
02-17-2003, 03:54 PM | #2 |
Fabricate till you "puke"
If its an I 6 , or a sb it has a 7/16-14 NC bolt approx 1 " long with a lock washer,& a large flatwasher......no other parts on the bottom. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-17-2003, 05:12 PM | #3 |
Thanks crazyl, I appreciate the reply. After a long, 10 yrs, the engine is going in.
02-17-2003, 05:26 PM | #4 |
I have had my longhorn for 18 yrs, the first 8 or 9 yrs it was pcs......I do understand about a long term project! dont priorities"bite"? good luck with the project....crazyL
