06-29-2010, 03:01 PM | #1 |
BBC to SBC Swap
Hi, I have an original '72 C10 Longbox 402 BBC, A/C, PS, and TH-400 that I want to swap to a 350 SBC. I am keeping the TH-400, PS, and A/C-what do I need to do this swap? I know I need new engine mount towers and mounts, but what else will I need?
Thanks-
1972 Cheyenne C10 Unrestored Original-3 Owner-RUST FREE Texas Truck Big Block-TH400-PS-PB-AC-AM/FM Radio |
06-29-2010, 03:15 PM | #2 |
Re: BBC to SBC Swap
ac compressor mounts and power steering mounts for a sbc. im assuming your doing it for fuel mileage?
1972 super cheyenne 1970 Suburb |
06-29-2010, 03:22 PM | #3 |
Re: BBC to SBC Swap
Yes I am for the most part. I have a nice original '71 350 4-bolt main engine needing a rebuild and would be the replacement when the 402 finally has to be replaced. Since the truck will be my everyday driver very shortly, I want everything ready so the 350 can go in when needed.
06-29-2010, 03:58 PM | #4 |
Re: BBC to SBC Swap
06-29-2010, 04:01 PM | #5 |
its all about the +6 inches
Re: BBC to SBC Swap
You'll need all new acc mounting brackets, exhaust manifolds/headers, mounts would be nice, but not needed, rad hoses, a small block fan shroud (the right mounts will make sure the right shroud will fit)... there may be a few more odds and ends too
06-29-2010, 05:12 PM | #6 |
Junior Member
Re: BBC to SBC Swap
Let me know if you decide to sell the motor and accessories.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
06-29-2010, 05:59 PM | #7 |
Re: BBC to SBC Swap
Sorry I am going to sell of any of the original parts.
-Brian
06-29-2010, 06:22 PM | #8 |
Re: BBC to SBC Swap
Im getting 13MPG (city and highway combo) with my 402-700R4-3:73 rear and 31" tires.It has a roller cam, HEI, high rise cast iron intake and a 800cfm QJ from Jet. Factory AC and PS. I dont think you can do much better with a 350 and t400. I would get an overdrive trans and matched gears for the rear and you might be around 18MPG. Just my opinion. And run a Q-Jet carb.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
06-29-2010, 06:50 PM | #9 |
Re: BBC to SBC Swap
IF YOU KEEP THE 72 BIG BLOCK TOWERS YOU CAN JUST USE THE 73 UP CLAMSHELL MOUNTS. THEY ARE MUCH STRONGER & EASIER TO LINE UP ON AN INSTALLATION. I REALIZE THEY AREN'T 100% CONCOURSE CORRECT, BUT NEITHER IS A SMALL BLOCK IF YOUR TRUCK WAS BORN WITH A BIG BLOCK, & THEY ARE A VERY NICE UPGRADE. IN MY OPINION. (BUT YOU KNOW WHAT THEY SAY ABOUT OPINIONS) I'VE HAD 6 CYL.S & THEN BIG BLOCKS IN THE SAME TRUCK & ONLY HAD ABOUT A 2 MPG DIFFERENCE, SO DON'T EXPECT A BIG IMPROVEMENT IN MILLIAGE. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 06-29-2010 at 06:53 PM. |
06-29-2010, 11:38 PM | #10 |
Re: BBC to SBC Swap
like said above...run a q-jet (or tbi swap) and put in an overdrive!!!
if you want to get the mileage of a 350 (or better) but have more of that big block punch......make it a 377 (or 383 if it needs to be more than a hone job). i have a 406sbc w/ low miles on a rebuild to put in my 72 burb otherwise i'd make a stroker small block out of my stock 307 (it would be a 354 w/ just a crank swap). an RV grind roller valvetrain is another great idea for daily driver duty! |
06-30-2010, 07:32 AM | #11 | |
Re: BBC to SBC Swap
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
06-30-2010, 06:17 PM | #12 | |
Re: BBC to SBC Swap
i have done the calculations: pistons from a 305 with a 400 crank makes a 325 pistons from a 307 with 400 crank makes a 354 my 406 is a 400 bored .03. remember that the 305 has tiny pistons with the 3-1/2 stroke (same crank as the 350), whereas the 307 has the 327's 3-1/4" stroke with slightly smaller diameter pistons than the 327/350 uses. |
06-30-2010, 08:18 PM | #13 |
Re: BBC to SBC Swap
I have a 2002 Chevy Silverado with a 5.3 LS and an overdrive trans and get around 16-17. 18mpg with a carb'd big block and an overdrive might be stretchin it...........
06-30-2010, 11:34 PM | #14 |
Re: BBC to SBC Swap
if you want to get the mileage of a 350 (or better) but have more of that big block punch......make it a 377 (or 383 if it needs to be more than a hone job). REREAD YOUR POST. SOUNDS LIKE YOU ARE CLAIMING YOU CAN HONE ABOUT .160 OUT OF YOUR 350 TO MAKE IT A 377 CID. I DON'T BELIEVE YOU CAN . (I KNOW YOU CAN'T) YOU NEVER MENTIONED A CRANK UNTIL YOU SECOND POST, & I'M A LITTLE RUSTY AT MINDREADING. IF YOU GIVE ADVICE, ITS VERY HELPFUL TO SUPPLY ALL THE INFORMATION OF PARTS COMPONENTS INVOLVED, JOHN
