06-29-2010, 03:31 PM | #1 |
Valve cover question
Ok, Im looking to buy new valve covers....need some opinions please...
So I found these edlebrocks that I like.... http://cgi.ebay.com/ebaymotors/Edelb...item563da648b0 But Im worried about leaks...So should I shell out 10 more bucks and buy these..... http://cgi.ebay.com/ebaymotors/Ball-...Q5fAccessories I was really set on a black finish but are aluminum's ALOT Less likely to leak?? Or should I be fine the edelbrock's?? Thanks |
06-29-2010, 03:51 PM | #2 |
Re: Valve cover question
I think you should be ok with the Edelbrock ones, if you´re worried, use some spreaders on the bolts.
67 c10 Short Step 350/th400 daily driver 69 Camaro work in progress |
06-29-2010, 03:57 PM | #3 |
its all about the +6 inches
i would go with the aluminum ones.
06-29-2010, 04:26 PM | #4 |
406 Powered
I just finished my 406 and put these on it.http://cgi.ebay.com/ebaymotors/SBC-C...Q5fAccessories No leaks and the flanges are well made. Plus i have not seen many on our trucks. The welds around the edges look cool and are perfectly lined up.Cheap price to. Just an opinion.
70 GMC 68 c10 2002 silverado 72 4x4 |
06-29-2010, 09:42 PM | #5 |
thanks for the input so far guys..... if anyone else has any more opinions on this, i would appreciate it.. thanks again
06-29-2010, 09:50 PM | #6 |
Active Member
Go with the AL ones - far less issues in my book
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
06-29-2010, 11:03 PM | #7 |
The aluminum ones look like they do not have baffles in them. I do not like oil sucking covers.
06-29-2010, 11:30 PM | #8 |
Don't go cheap, get a good set , it will be worth it in the long run. Also get a set that has at least one hole in each, one for pcv and the other for a breather.
06-30-2010, 06:29 AM | #9 |
Be careful about buying the tall covers whether steel or aluminum. I've found that the tall covers interfere with the alternator when it is attached with stock brackets.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
06-30-2010, 07:54 PM | #10 |
x2....
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
06-30-2010, 07:58 PM | #11 |
Between Trucks...
Finned. I got em off Fleabay. Fit and finish were excellent and they have baffles.
Beat it to fit, Paint it to match... |
