06-29-2010, 07:32 PM | #1 |
HEI Distributor
Going to make the move from points etc. to HEI. Would like to go with MSD. Seems like I have a choice between built in coil or external coil. The built in coil looks like a fatty. The big block sits in place of the small block. Shortened the drive shaft and moved the transmission etc. to fit the big guy. Can't tell if I will have firewall interference issues or not. Would like your input before I plunk down a chunk of change. I want the install as close to plug and play as I can get.
Original owner '69 C20, long, fleet. 454 BB with Edelbrock stuff. Work truck for years, 2nd restoration going on. '69 C20 '03 Tahoe Z71 70 Hp Johnson pushing aluminum bass boat. All things in life are uncertain, so eat dessert first. |
06-29-2010, 08:29 PM | #2 |
Re: HEI Distributor
This will probably be the easiest, cheapest and quickest.
http://www.pertronix.com/prod/ig/ignitor/default.aspx |
06-29-2010, 08:29 PM | #3 |
Active Member
Re: HEI Distributor
Before you spend a bunch of money on a new one go to a junkyard and look for a cheap one to see if it will fit. May save you some frustration later on-- and a few bucks...
06-29-2010, 08:34 PM | #4 |
Re: HEI Distributor
I just bought a Skip White HEI on ebay for a real good price.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
06-29-2010, 10:00 PM | #5 |
Active Member
Re: HEI Distributor
I bought the pertronix III Dist and coil - replaced my MSD unit and it works much better
Has the built in multi strike from idle up and a built in rev limiter I bought the small cap with ext coil - to replace the all built in large cap HEI
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
06-29-2010, 11:57 PM | #6 |
Re: HEI Distributor
Thanks to all. After taking another look I believe I will have to go to the small cap with ext coil. Just not much room between existing distributor and the firewall, don't hink I can make the turn without some serious wrenching. Will check the yards for any decent used stuff first. Believe I did this awhile back and not much around these parts.
Again thanks for your input.
06-30-2010, 06:46 AM | #7 |
Re: HEI Distributor
pertronix(made in usa) makes a really nice billet smallcap hei that uses an external coil and looks like a standard points type// tho a bit pricy i've used a few times and you cant beat the looks and ease to set it up
IMO msd is overly complicated with tons of gimmickery stuff that really has no real advantage for a normal streetdriven vehicle/// lots to figure out lots to go wrong lots of wires and generally not worth the effort loads of features that r never used during the life of the unit
06-30-2010, 11:26 AM | #8 |
English Chevy Owner
Re: HEI Distributor
I've just ordered the Pertonix ignitor kit to convert my twin point mallory as I have the same problem, stock HEI just won't fit in. Should be here tomorrow and then I need to fit it, picking up their Flamethrower coil to go with it too.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
