Old 06-30-2010, 12:13 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
brakes still feel like ther hanging..
I drive down the road after a few miles my brakes (front disc), start squealing etc. I have relatively new brake pads (6 months on a DD). Im going to try to adj. my brake rod, but think its adj. to its max. It has new lines calipers etc.
What can I do, i will check the adj. for sure this evening, Thanks!
John
1999 Toyota Tacoma 4x4
Old 06-30-2010, 01:00 PM   #2
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Re: brakes still feel like ther hanging..
I know you said you have new calipers (rebuilt most likely) but I know if the caliper bolt bushings are worn or missing those can squeak?? I had that problem on a 73 I owned back in the day... really simple and cheap to change
JNJchev77 is offline   Reply With Quote
Old 06-30-2010, 02:20 PM   #3
cdowns
cdowns's Avatar
do you have a combo valve for disc/drum system if you have one for drum/drum it wont release the calipers and cause diiscs to overheat and warp
Old 07-06-2010, 10:19 PM   #4
gary2232
Had the same problem. Checked and changed everything. It turned out to be the pucks in the caliper need to be removed and cleaned. I ended up flushing the system. I thought it was the rod and portioning valve. But it was a easy fix. Drain and flush system and rebuild calipers.
gary2232 is offline   Reply With Quote
