Old 06-16-2001, 05:58 AM   #1
chaz
Question HELP!! 87 won't start
87 GMC PU, 350,FI,2 whl dr, dual tanks....have spark - no gas spray from injectors., early on it has run for 20 mins then blows ECMB fuse - now won't start at all (fuse dosn't blow now), have checked; fuel pump, fuel filter, tank switch, fuel relay, oil pres. switch, ignition module, all wire connections, coil,,,, fuel pump runs for 2 sec. when key is turned "on" then shuts off,sometimes it runs like it's flooded (need to raz the throttle to keep it going) I quit reading my repair manuals and tapped open the keg
chaz is offline   Reply With Quote
