Old 06-30-2010, 10:42 PM   #1
rodstored-72
chevy truck fan
rodstored-72's Avatar
Question ac compressor connection question(s)
all,
i have a vintage air "universal" ac system installed in my 1972 chevy truck. i am running a 350 (383) with a '92 p/u serp. belt system. my r4 "disk" compressor has 2 wires running (white & blue) from it. i am installing a holley throttle solenoid to adjust the idle when the compressor kicks on.
i want to know what wire is the "kick on" wire that i need to connect to so the solenoid will operate at the right time?
i believe that it needs to be the power wire, but i am not sure....
thanks for any input from you guys!!!
rodstored-72
rodstored-72 is offline   Reply With Quote
Old 07-01-2010, 03:11 PM   #2
rodstored-72
chevy truck fan
Re: ac compressor connection question(s)
Anyone????
Old 07-12-2010, 02:17 PM   #3
WFAPS
One of the wires is power and the other is a ground. Unhook the connector from the compressor and with the ingition key on or engine running, turn on the a/c. With a test light or voltmeter check for 12v in both wires only on will have 12v. Tie into the wire with 12v for the idle up solenoid.
WFAPS is offline   Reply With Quote
