07-01-2010, 12:00 AM | #1 |
Oil Pan Gasket
I recently discovered that my rear main seal is leaking pretty bad and possibly my timing cover. I'm guessing it's an early 70's model 350, not sure, the truck is a '68 so the motor's not stock, one've these days I'll pull the valve covers and find out. Anyway I never really done any engine work so I'm not really sure how to go about doing this, So any help would be awesome, Thanks Yall!
'68 C10 LWB 6.2NA/NP833 3.73's |
07-01-2010, 12:19 AM | #2 |
Active Member
Re: Oil Pan Gasket
To learn what engine you really have you have 3 places to look
Passenger side front of the motor right below the mating surface of the head to the block You will find a 1.5" x 3" long pad that contains alpha numeric codes Post that information and we have a start On the back of the block - passenger side you will find an numeric code(this is your casting code) - on the opposite bank you will find another alpha numeric code(this is your date code) Post this information and we can confirm what the block is
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
07-01-2010, 04:40 AM | #3 |
Re: Oil Pan Gasket
felpro makes a one piece gasket thats about 40 or 50 bucks and it works real nice
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
07-01-2010, 05:58 AM | #4 |
Re: Oil Pan Gasket
a factory service manual is a great investment ,shows step by step the proper way to do a job such as this and how to inspect the internal parts for wear to avoid replacing unneed parts and how to reassemble correctly
07-01-2010, 07:58 AM | #5 |
Re: Oil Pan Gasket
The block casting number is on the driver's side rear just behind the back of the head. That will tell you what block you have - 307, 350 etc. and a range of years & applications it was used in.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
07-01-2010, 09:22 AM | #6 |
Re: Oil Pan Gasket
WHEN THOSE SMALL BLOCK 1 PIECE PAN GASKETS CAME OUT A FEW YEARS BACK, I TRIED ONE & HAVEN'T USED ANY OTHER KIND SINCE. THEY ARE FANTASTIC. THE LAST 1 I BOUGHT WAS ABOUT A YEAR AGO (I THINK AT AUTO-ZONE OR CAR QUEST O-REILLYS. I'M NOT SURE BUT IT WAS ONE OF THOSE CHAIN PARTS STORES) & WAS UNDER $25. THEY ARE GREAT. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
07-01-2010, 10:23 AM | #7 | ||
"I ain't nobody, dork."
Re: Oil Pan Gasket
The pad on the front of the passenger side cylinder head will have the engine suffix code. Then you can figure out what year, c.i.d., HP rating, and what appliction the engine is. If you get the one piece Fel-pro gasket (which are great), you need to make sure you get the proper one that fits the timing cover to pan seal. There are 2 sizes... thick and thin.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
07-01-2010, 12:35 PM | #8 |
Grandpa in the rustmobile...
Re: Oil Pan Gasket
i got my motor on a stand and have a 2 piece gasket, should i swap to 1 piece or just leave it alone..
edit,its all new stuff
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 Last edited by oldblue1968chevy; 07-01-2010 at 12:36 PM. |
07-01-2010, 01:36 PM | #9 | ||
Re: Oil Pan Gasket
Your choice... But the 1 piece is superior IMO.
Just make sure to get the correct gasket depending on your timing chain cover to pan seal. Gary
07-01-2010, 01:43 PM | #10 |
Re: Oil Pan Gasket
Ok just went and looked at the numbers, they were a little different than described, that or I got it backwards. I found two numbers, one which was on the back of the motor on the lip that attaches to the transmission on the driver's side, 3970010. the other on the passenger side of the block on the lip, G28(?) I couldn't make out the last figure, and unfortunately that's the number I need to know. I did a little research, the first number means it's a '69-'79 350, the second from what I could get means July 28, I'll have to check again to see if I can make out the last number.
07-01-2010, 02:04 PM | #11 |
Re: Oil Pan Gasket
OK just went and looked again, took a few pics, let me know what yall think.
07-01-2010, 02:11 PM | #12 |
Active Member
Re: Oil Pan Gasket
Great - that is your date code =- go to the other side of the block - same area but in a larger font will be you casting code.
Sometimes we need to put together a couple of items to make sure we know for sure what we have. G = July 28 should be the 28th day of the month 1 = should be a 71 motor The other option would be July 2 1981 - the blue paint makes me question the date - it would be correct for a 81 motor - but the way the casting number is laid out it looks like the 28 belongs together
07-01-2010, 02:19 PM | #13 | ||
Re: Oil Pan Gasket
What is the number stamped on the pad in front of the passenger side cylinder head?
Gary
07-01-2010, 02:21 PM | #14 |
Re: Oil Pan Gasket
^yup that tells it all...
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
07-01-2010, 02:21 PM | #15 | |
Re: Oil Pan Gasket
07-01-2010, 02:26 PM | #16 | ||
Re: Oil Pan Gasket
If you get the number off of the area in front of the passenger side head, you will get the engine suffix code. The last 3 digits in that number.
The suffix code will tell you the exact year, c.i.d., HP rating, and how many barrels the carb was from factory. Gary
07-01-2010, 02:47 PM | #17 | |
Re: Oil Pan Gasket
07-01-2010, 03:53 PM | #18 |
Re: Oil Pan Gasket
im running a 2 piece gasket on my 347 stroker.. and it'll be fine.. i just like the one piece because i heard you dont any adhesive or what not and i also heard if you take your oil pan off in future u can still use that same gasket
07-01-2010, 04:01 PM | #19 |
Moderator
Re: Oil Pan Gasket
What is your 2 piece composed of? If it is cork, I would replace it with a 1 piece. If it is rubber, I would leave it alone. I like the 1 piece because it is easy to install, but the best thing is that it is made of rubber and will not leak.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
07-01-2010, 05:11 PM | #20 | |
Re: Oil Pan Gasket
07-01-2010, 05:57 PM | #21 |
Re: Oil Pan Gasket
I've been doing a little research to see if I can do this whole thing without lifting the motor a few inches but it look like I'm gonna have to. I'm not real sure where to hook the chain for lifting it. I don't have an engine hoist but I have a tractor with a front end loader which oughta work pretty good. Also is there any special links or hooks I'll need?
07-01-2010, 05:58 PM | #22 |
Re: Oil Pan Gasket
BY ALL MEANS... CHANGE IT NOW WHILE IT'S NICE & EASY TO GET TO. BUT THATS JUST ME... I'M A LAZY SH!T AT HEART, & IF YOU'VE EVER LAIN ON YOUR BACK, UNDER ONE OF THESE OLD TRUCKS & WRESTLED THE OIL PAN OFF... WELL I'D RATHER BE BEAT WITH A STICK. AWFULLY CHEAP INSURANCE. AFTER USING THEM... I'M SURPRIZED THEY EVEN MAKE THE OLD TWO PIECE CORK BUGGERS. THEY ARE THAT GOOD. I ALWAYS BELIEVED IN FEL-PRO GASKETS & I'VE GOT TO BE THIER #1 FAN. THIS IS 2010 & THATS 1952 TECHNOLOGY AT IT'S FINEST. JOHN
07-01-2010, 08:10 PM | #23 |
Re: Oil Pan Gasket
when i built the motor for my truck, i used the old style cork junk and had a nice fat oil leak, luckily it was on a test stand and was easily changed to a felpro one piece gasket. autozone had it in stock, there are only two kinds, the difference has to do with the thickness of the gasket at the front where it meets the timing cover. if its a pre 1980, i believe its the thicker one, and if its a post 1980 they changed it too the thinner one. this is the year of change on which side the dipstick is on too. i do remember at first i thought i had the wrong one because it was looking too thick where it met the timing cover, but after starting the bolts and little shoving, it fit like a charm and has never leaked again. the gasket also has little steel hoops around where the bolts go through it so you can't over tighten the pan bolts too easily.
07-01-2010, 08:21 PM | #24 | |||
Re: Oil Pan Gasket
My suffix code is TDJ Gary
07-01-2010, 10:47 PM | #25 |
Re: Oil Pan Gasket
Thanks for your help Gary, I think I've got it. My suffix code is TYZ which translates: year: 1975, cid: 350, hp: 165, carb: 4bbl. So does this mean the last number on my Casting date is supposed to be a 5? sure doesn't look like it, were these numbers ever known to come out crooked from the factory?
