Old 07-01-2010, 08:23 PM   #1
292farmer
292farmer's Avatar
rear discs need help.
i recently heard a scrapping from my rear and pulled wheels off to inspect brakes and well...its bad i need everything and to give u an idea their 12in brakes worn to 12 and 7/16 and so thin and see through u can twist the drums with your hands(im not kidding). anyways priced everything out and came up with 375-425$(including lines) so was thinking why don't i use this as a chance to but rear disc brakes and think i found a good kit that costs a little more then my stock parts, heres the linkhttp://www.blackbirdscustomtrucks.com/index7.html#4d60 has anyone dealt with these guys is that an reasonable price? are their other kits avaiable? i couldnt find any. BTW my truck is a 72 c25 gmc with a dana 60 im looking at kit w e brake. thanks everyone.
292farmer is offline   Reply With Quote
Old 07-01-2010, 08:34 PM   #2
btullis99
btullis99's Avatar
Re: rear discs need help.
I'd take this opportunity to do the upgrade, looks like a pretty standard rear disc kit. youll have to change your proportioning valve, wilwood sells a really nice one for $60 or so.
btullis99 is offline   Reply With Quote
Old 07-01-2010, 09:04 PM   #3
292farmer
292farmer's Avatar
thats true will they specify whether the prop valve is designed for all around discs or do i look for an adjustable one?
will this one work?http://www.wilwood.com/MasterCylinde...derValves.aspx part number 260-8419
Old 07-01-2010, 09:22 PM   #4
btullis99
btullis99's Avatar
Yup, that's the exact one I was talking about. I've got one, haven't got it installed yet, but it comes with easy instructions on how to adjust it properly. it can be adjusted to work with any brake setup, drum drum, disc drum, or disc disc.
Old 07-01-2010, 09:29 PM   #5
btullis99
btullis99's Avatar
sorry, didn't see the part number you put in, the one i have is 260-11179, got it from summit for 60 or so. http://www.summitracing.com/parts/WIL-260-11179/
Old 07-01-2010, 09:56 PM   #6
71 super
71 super's Avatar
blackbirds is a good company and were members here at one point. they deal with 3/4 stuff and are easy to deal with.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 07-02-2010, 06:04 AM   #7
292farmer
292farmer's Avatar
i see that valve your talking about has three outlets, so u could run a seperate line to each front caliper, is their an advantage that way over the single one that spilts at the frame to each caliper? good to hear that their a good company was worried buying something over internet with out knowing who they are. they so far seem to have the best prices on kits for my truck.
Last edited by 292farmer; 07-02-2010 at 06:05 AM. Reason: forgot to say thanks for your guys info! thanks!
Old 07-02-2010, 12:04 PM   #8
hchad18
hchad18's Avatar
http://www.tsmmfg.com
hchad18 is offline   Reply With Quote
Old 07-02-2010, 07:11 PM   #9
292farmer
292farmer's Avatar
if i figured out that website right its 339 for the rotors and mounting parts and then either an extra 120 for none ebrake and 320 for ebrake calipers? thanks
Old 07-02-2010, 07:25 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
You should look in our Vendors Marketplace. Capt Fab has some very nice disc conversion brackets for the Do-it-Yourself kind of guy. He is a great guy to deal with too.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-02-2010, 10:04 PM   #11
btullis99
btullis99's Avatar
I'm just gonna plug one of the front outlets, it says that it doesn't matter in the instructions if you do or don't. its just giving you the option.
Old 07-04-2010, 11:36 AM   #12
292farmer
292farmer's Avatar
thanks guys, i'll give that market place a check.
