parts
where is the best place to get new parts. i need front fenders and variuos other parts, i have some catologs from lmc ecklers and brothers but is there another place that may be cheaper? i also have a gaping hole in the inside
just above the drivers door it is about a foot long and maybe 4 inches tall and it takes up some of the door frame where the weatherstripping would attach i will try to post some pics if i can remember how but in fixing the hole do i need to take the entire roof apart? thanks josh |
Re: parts
Senior Enthusiast
Re: parts
My experience has been that Chevy Duty (now Classicparts.com) has the best pricing, good service and quality products.
http://www.classicparts.com/ I have purchased quite a bit from American Classic Truck parts, http://www.americanclassic.com/ but they now have a $25 minimum order quantity, so most of my meager truck budget for parts goes almost exclusively to Classicparts. I'd suggest get catalogs from all the suppliers, then compare prices (or check online). You'll find that some of the biggest advertising vendors also have the highest prices. Sorry I can't help with the sheetmetal repairs, perhaps some of the experienced fabricators will chime in.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 Last edited by markeb01; 07-01-2010 at 09:47 PM. |
Re: parts
hopefully that monstrossity has bothered me for almost 14 years when i got her, just have not had the tools or time to tackle that problem.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: parts
On fixing that rust hole, it wouldn't be absolutely necessary to remove the roof. Is there any rust appearing on the outside of that hole? Probably the easiest fix for that would be to find a donor cab to cut a piece out of from that location. You'll want to be sure to get a piece a bit bigger than what the hole looks like now, as the rust and thin metal will extend beyond the actual hole. You will want to cut the hole in your cab back to where the metal is close to the original thickness.Of course welding will be necessary to install the replacement piece. If you don't have the equipment or skills to do this yourself, ask around and see if you can find someone willing to take this on. There may be another member close to you that could help out. I know there's several here from OK, but I don't know how close they might be to you.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 07-01-2010 at 10:38 PM. |
Re: parts
okay i have a few more questions. if i get 85 chevy truck frame with the front end would it be easier to swap front ends or put my body on the 85 frame. also where can i get parts for a streering column, and do i have to pay to trade parts or just sell?
PIMPING RIDES
Re: parts
you should try 456 chevy in the salvage parts .you probaly can get some use fenders and doors cheaper .tony is great go here and post what you need http://67-72chevytrucks.com/vboard/s...278115&page=55 .
1964 CHEVY 1/2 C/10 FLEET ![]() 1981 CHEVY 1/2 C/10 FLEET ![]() 1995 DODGE 1500 V6 FLEET ![]() EAST http://www.flickr.com/photos/bigasspimp/?saved=1 |
60-66 Nut
Re: parts
Just install the '85 front suspension under your '62. The frame under a '85 is different enough to make a body swap not a good idea.
If you're not a supporting member, you can buy parts, you just cannot post a want to buy, want to trade, or what's it worth.
